20 Most Recent
Weller SP80 Soldering Iron Questions & Answers
How to disassemble weller soldering iron Magnastat
Hello, if the head element in the barrel of this soldering iron is shot. Recycle
it and save the copper and other materials for recycling. Recyclers are pay
$3.20/lb for copper, $1.86/lb for brass.
Remove the three screw on the front plate and pull the cord. It's apart.
GB...stewbison
How to remove a weller sp 80 tip
Just loosen the screw in the barrel near the tip, then rotate while pulling the tip out. It shouldn't be necessary to remove the tip unless it requires replacement. Hope this helps!
I need a replacement screw that holds the
Chances are that the screw and maybe the hole in the iron barrel have been 'cross threaded'. Remove the screw and the tip, then examine the screw and hole threads for thread damage. If they are, the screw should be replaced, but the hole in the barrel will need to be cleaned with the proper size tap. You can find the tap and the screw at a home center, or hardware store , plus get some suggestions on how to fix your problem. Hope this helps!
INDICATOR LIGHT ILLUMINATED THEREFORE POWER TO
The most likely problem ishte heater inside the pencil. This can be replaced for around $25. Check with a local electronics supplier for the replacement parts. They are readily available on teh web too. I believe that MCM Electronics. Digikey and Mouser all have these parts available.
Dan
Weller tcp 1iron overheating
There is a bimetalic strip and a magnet that can get stuck in the closed position.
Tapping the iron on the end of the bit can release it otherwise a new element will be required.
I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Can u use the Weller universal soldering gun for making and repairing jewelry?
Unless you are only interested in soldering tin/lead joints... I sincerely believe that answer to be "No"...
What kind of metals were you planning on working with
would be a GREAT PLACE to start...
and the figure out the temperatures you will need to achieve..
A word of extreme CAUTION.
Working surfaces have to be able to withstand EXTREME TEMPERATURES.
Cement will come apart with explosive force... and getting any water onto molten metal can also have catastrophic consequences... so a little supervised experience would be well advised place to begin...
