20 Most Recent
Gestetner A045 Wide Format Copier Questions & Answers
Looking for some one to work on a gestetner a045
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Have scanned several plans put in pdf format and
When you select the user or the path for the folder you can view it on the screen. Simply type in your PC the path to see where you are sending.
On your PC click the start button, then RUN. Write the Path you see in the machine. At last ENTER
Hope this helps!!!!!!!!!!!!!!!!!!!!
reply any questions ok?!
In scanplot base software in A045 machine gives
This requirement and solution are in the Plotbase manual, not the copier manual. See pp. 29-30 Setting for RW-240 ScanTool.
1. Start - Control Panel - Administrative Tools
2. Local Security Policy
3. Local Admin Policies
4. User Right Assignments
5. Lock Pages in Memory - Local Security Setting
4. Add User or Group, then Advanced
5. Add or Find Now - select users (all)
6. OK
7. close Local Security Setting windows
Help my A045 Gestetner will not load paper after
If you are changing a paper roll, make sure you can advance the paper through the "throat" using the green knob and then manually trim it. If you are loading paper in the cassette tray, make sure you adjust the green sizing guides to match the paper dimension (8.5x11", 11x17), etc.
