20 Most Recent
NovaLogic Delta Force V: Black Hawk Down for Windows Questions & Answers
Single player option is disabled
Probably a problem in your .exe file....try a crack,patch or insert your cd and try......all worked for me...I used a no cd crack
Download serial number
you could search on "thepiratebay" but it is illegal to use Keygens or similar to get serial numbers of Games that are sold for money.
Program error: polytrn map not
The "polytrn color map" is a component of the terrain that makes up part of the Irene map and is packed into the localres.pff file in the BHD directory. If it's missing, it means the game hasn't installed properly for one reason or another. So uninstall / reinstall it again and then run the ingame update feature before trying to join the Irene server again.
When I play Irene in
I get the same error when i play Delta Force: Black Hawk Down:
First stage i.e., Marka Breakdown, i get this !polytrn
color map not specified.
I tried to download the Dirext X 9.1 during the insallation of the game but it wouldn't and its a stand still.....
Any sggestion would be great.....:(
Comanche 4 activation key
From the Novalogic FAQ page, " Your Comanche 4 Product Key Code can be found inside the Comanche 4 jewel case."
If you need to purchase a product key, you'll have to contact Novalogic as their online store says out of stock.
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
