20 Most Recent
Siemens WT79020EU Electric Dryer Questions & Answers
Siemans dryer door does not make good contact to get dryer started. Have to lift door to turn on dryer
By pulling up on the door tells me that some adjustment is needed to the door or the switch. Check to see if the switch has broken at the tip, or bent back a little. Also see if any screws that hold the switch in place need snugged up to make it stick out of the holder more. You may be able to see the screws just beside the switch. You may be able to use your switch by gluing a thin piece of something to the toggle. Just be careful that you use something capable of taking the heat. Just had to replace the switch on my dryer last week. Got switch off of amazon for 8.00 bucks. MAKE SURE it is the right switch when ordering. I am a do it yourselfer.. not a pro.
10/15/2014 3:49:29 AM •
Siemens...
Answered
on Oct 15, 2014
Dryer stops after a few minutes Siemens WTXL2101 EU/07
Maybe a sensor at the back sensed overheating. You might be able to remove the backplate and search for a little button, which acts as some sort of reset button. (I do have a different tumble dryer, but it's the same brand and had similar problems). Maybe more ventilation is needed to prevent this from happening again.
4/7/2013 6:41:31 PM •
Siemens...
Answered
on Apr 07, 2013
Dryer stops drying and lint error message...
try cleaning the vent line. if you have a flex vent line make sure it isn't kinked in any spot. make sure the outlet outside does not have a birds nest or anything blocking it
5/23/2012 7:57:58 PM •
Siemens...
Answered
on May 23, 2012
Dryer will run and rotate but there is no heat.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101';
8/18/2011 11:57:01 AM •
Siemens...
Answered
on Aug 18, 2011
The dryer is blowing cool
gas no heat tip....
check outthis
heatman101
5/15/2011 1:42:21 AM •
Siemens...
Answered
on May 15, 2011
Removed front of dryer to
On most dryers, the front panel helps hold the drum in the proper position. The bottom of the drum usually rolls on rollers at the rear and is connected at the rear center with some type of bearing. Make sure it is in the proper position at these spots. Look on the front panel for something that will fit into the drum front opening and hold the drum front up while putting the panel in position.
12/31/2009 7:41:04 PM •
Siemens...
Answered
on Dec 31, 2009
