20 Most Recent
Electronic Arts Command & Conquer: Generals Zero Hour for Windows Questions & Answers
I downloaded rise of the
just delete the installation folder itself and then run a good registry cleaner and you will be fine
C&C Generals Zero Hour problem play on windows 7 64bit
Try patching the game, think that was a known issue and had to be resolved by actually patching the game. Also sounds like you might be playing a skirmish instead of missons, check what your doing. If you set up everything in the beginning such as who you fight against, your playing against the CPU and not actual missons.
DrakeTech.
When i try to install my game it says that it cant
you have a couple of options.
- Try copying the contents of the ZH disc to the hard drive, then install ZH from that HDD copy
- Follow the second thread (by a poster names Subroutine)
Let me know how it goes. I love that game..
No mena on C&C zero Hour
Try going into the
EA games files and find the file containing the Game application. Right click on the .exe file and select properties. Go to the compatibility tab and select file to run as XP service Pack2 and as administrator. now click apply and try running the game. If this doesn't work you can www.commandandconquer.com forums they have a FAQ for problems its recommended.
hope this is helpfull
let me know how it goes.
Technical Difficulties
You could try to renistallboth generals and zero hour. If that doesn't help, and you really want to play the game, you could try reinsaling Windows, because that then probably is the problem.
I hope this helps,
Yannick.
