20 Most Recent
ValuSoft Hunting Unlimited for Windows Questions & Answers
Installed Hunting unlimited but said sys-no-graphics
Hi , i finally solved it .Before you start the game ,just go to advanced settings and change graphics to low . Change screen resolution to 800x600 . it will work . Change to high resolution after game starts .
Thanks
Sys no graphics
imam problem nemogu da pokrenem lov izbacuje nesto sys no graphich
I click the game for hunting unlimited 2009 but it
If you are using this game on a different computer than you have in the past the graphics card in your computer may not be sufficient enough to run that software. You should check the requirements of the game either on the back of the box or in the read me file and then compare it to your system. You do this by clicking on the control panel, under the system section there should be a listing to test your windows experience base score this will provide you with info about your system's graphics accelerator and sound card used for gaming
Installed hunter unlimited 2011 on
I had to update the chipset drivers and flash the bios to get the hu2011.exe to work it loads fine now but the graphics are lacking in the near range. They are blacked out but the far range graphics are fine.
Im trying to play hunting unlimited 2008 on my
Try to download a newer graphics driver from the site of the VGA card manufacturer. And check the DirectX version. Try to upgrade to the version that is in the specifications, or above
