20 Most Recent
Capcom Resident Evil: Code Veronica X Questions & Answers
A place for 6 diffrent pictures
I had ths same problem when I got to this part of the game but I finally got it! This is the solution to your problem let me know if this works Good Luck!
1) Lady Ashford
2) Stanley Asford (Man holding two babies)
3) Thomas Ashford (Man holding a cup of tea)
4) Arthur Ashford (Man with red hair)
5) Edward Ashford (Old man seated near a vase)
6) Alexander Ashford (Man leaning on a mantle)
7) Alfred Ashford (on steps)
Where do you use the dragonfly key
USE the dragonfly object on the painting of an ant on the wall in the same room you get it . Oh and yes , you must 1st detach the wings
Resident evil code vernica for ps2
I say the best thing for you to do is go to google and type in walkthrough for resident evil code veronica x for whatever system you have the game to help you out on that. Also you can have it if you happen to get stuck on another part you will have something to help you out. Let me know if this works Good Luck!
I put the disc in,
try playing with no mem card then plug it in afterwards.just bypass it with no mem card then plug it in when you will load your game
Sayes disk err can read disk
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
CLICK HERE TO ORDER YOUR NEW REPLACEMENT DRIVE(ROM)
I am in a place where there are 6 pictures
oh this is a good one but easier then it seems so here goes.
First, press the button underneath the picture of the female, Veronica. After this, you shall go
over and press the button beneath the man with two baby boys in his
arms. After this, walk over to the man on the right without the book and
press the button underneath its' picture. The fourth button that wishes
to be pressed resides underneath the picture of the man that looks like
Ben Folds with red hair. After this, select the picture of the man
reading the book, and push the button to it. We're getting close to the
end. Press the button underneath the picture of the blond man middle-
aged man, which is the last of the bottom pictures. Now, press the
button underneath Alfred Ashford, the one above the steps.
I am stuck in a room with 6 pictures on the wall.
That one is a brain teaser. the solution is that you must correctly place them in order from the oldest ancester which is veronica. then comes the man with the red headed twins,the babies.after him comes the red-haired man with the teacup, his son. Then comes his brother, the other red-haired man with the white plate in the backround.Then comes the man with the earthenware vase in the backround. Last comes the man with the white candlestick. Good Luck on the rest, you'll need it!
I am in a place
ok problem solved
you need more pphotos.
will be glad to help.
regars,
daniel.
Find local setting folder
I will answer this in a Liner sequence. Follow step by step.Start>Control Panel>Folder Options>View>check Show Hidden Files and Folders>uncheck Hide Extensions for known File types >Hide Protected Operating System Files and folders. Start>Computer>C:/Users>[your username/username of local settings you want to find\]>Local Settings.If access is denied you can take ownership of the folder if your using an administrator account.Right click - Properties>Security>Select [your username]>Advanced>Owner>Edit>[select your username]> check Replace Owner on sub containers and objects>Apply>YesClose all windows and reopen.Do not attempt to alter settings in this folder It can lead to serious damage to your computer and / or applications. Altering settings in this folder will at the very least cause programs to stop running properly. There is nothing in this folder that can be used to fix a computer.
