20 Most Recent Dell Vostro 1000 Laptop Questions & Answers
3answers
I need key for driver restore
Davis, You can restore the system to factory conditions by following the information below. Dell Factory Image Restore The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu. Start the computer and TAP the F8 key. Once the options appear on the screen you can choose Repair Your Computer and follow the prompts to restore the computer to factory conditions. CAUTION: This utility formats the operating system hard drive partition prior to restoring the factory image. This means data on that partition is deleted and cannot be recovered. If the customer creates a second partition with a third-party utility, Dell Factory Image Restore is not affected as long as the image partition is not removed. Thank You, Dell-Jesse L Dell Social Media and Communities
6/24/2018 11:18:12 AM • Dell Vostro 1000... • Answered on Jun 24, 2018
Dell vostro 1000 laptop power problem.
older vostros usually have a broken dc jack right where the power connector plugs in. otherwise try another ac adapter and also try removing and replacing the battery underneath.
1/30/2018 12:35:04 AM • Dell Vostro 1000... • Answered on Jan 30, 2018
If battery light is on can battery still be bad?
Yes it can, the battery has its own sensing circuit inside. When they go bad, they tell the computer not to boot.
5/13/2016 3:43:15 PM • Dell Vostro 1000... • Answered on May 13, 2016
Can dell vostro 1000 be repaired if hdd password unknown
when a password for a laptop is forgotten there is no need to loose hope and format the laptop since it will mean losing all the data .more info http://opencertify.blogspot.com/p/how-to_26.html
7/27/2015 5:39:58 AM • Dell Vostro 1000... • Answered on Jul 27, 2015
How do I transfer everything from my Dell Vostro 1000 to my Toshiba Laptop
Hello, You may transfer the files and settings from one computer to another by using Windows easy transfer: Download link: http://windows.microsoft.com/en-IN/windows7/products/features/windows-easy-transfer Instructions to transfer data: http://windows.microsoft.com/en-in/windows/transfer-files-settings-from-another-computer#1TC=windows-7 Hope this helps..
3/5/2015 6:13:02 PM • Dell Vostro 1000... • Answered on Mar 05, 2015
Helping out!
Open control panel -> network and sharing center (Vista/Win 7) and change adapter settings. See if wireless network card is available. If not, get the driver from manufacturers web site and install it. If the driver is installed, check that WLAN is not disabled by some mechanical button on laptop. Some models have these.
6/4/2014 12:12:59 PM • Dell Vostro 1000... • Answered on Jun 04, 2014
How do I get my Vostro 1000 to bootup
Try going into safe mode. Press F8 when you start the computer and then select "Safe Mode with networking" you should then be able to run a couple of diagnostic programs or a virus checker. You can even do a system restore from there.
5/2/2013 7:44:25 PM • Dell Vostro 1000... • Answered on May 02, 2013
Forgot password at log in
You can try a system recovery.
12/9/2012 9:44:41 PM • Dell Vostro 1000... • Answered on Dec 09, 2012
How to disable Sticky keys
Start > Control Panel > Accessibility Options. Uncheck.
10/3/2012 4:28:15 AM • Dell Vostro 1000... • Answered on Oct 03, 2012
2answers
How do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
9/26/2012 6:43:49 AM • Dell Vostro 1000... • Answered on Sep 26, 2012
Failed association wireless connection
Did you reconfigure your router after you changed providers? Did you go from a phone company provider to a cable company provider or vice versa? If so they use different protocols and the router will need to be reconfigured. Phone companies such as AT&T use what is called PPOE and you have to put your Internet or Network userid and password into the router, you also will have to Bridge the router in most cases. Cable Companies use DHCP and there is no userid or password that has to go into the router.
4/5/2012 3:03:14 PM • Dell Vostro 1000... • Answered on Apr 05, 2012
Battery low while already plugged in
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
3/27/2012 7:14:58 AM • Dell Vostro 1000... • Answered on Mar 27, 2012
Unlock my Facebook account?
Go to the facebook webpage and hit the forgot signon and password.
8/27/2011 8:47:38 PM • Dell Vostro 1000... • Answered on Aug 27, 2011
My laptop has been switching
This is most likely caused by overheating. This is very common in laptops and can be fixed by getting a laptop cooler or making sure that the vents on the bottom of the laptop will have plenty of airflow. This can be done by using it on a hard surface or slightly elevating it near the vents.
5/11/2011 1:29:00 AM • Dell Vostro 1000... • Answered on May 11, 2011
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
3/1/2011 11:21:12 AM • Dell Vostro 1000... • Answered on Mar 01, 2011
I have a dell vostro
ok.Tell me more about this problem.
Have you tried to connect an external monitor to the laptop?
1/22/2011 11:59:50 AM • Dell Vostro 1000... • Answered on Jan 22, 2011
I put my Dell Vostro 1000 laptop on charge and
Hi there its sound like SMPS ( power supply Unit ) problem. Some how he not able to accept the power or hold the power and then forward it. It Is complete hardware problem.
1/17/2011 7:18:24 PM • Dell Vostro 1000... • Answered on Jan 17, 2011
I connect the ac adapter
That is a hallmark of a failed DC jack...or a bad motherboard. I'll address the simplest thing first. The jack pin often comes loose. If you check the pin and it is not loose, test the computer with a known good compatible AC adapter. This will likely tell you what is causing the problem.
11/1/2010 9:31:19 PM • Dell Vostro 1000... • Answered on Nov 01, 2010
I have a Dell Vostro 1000. I open the cover press
Hi.
Based on the information you have provided, the issue might be due to any of the Hardware components in the Computer.
However, you may try removing and re-inserting the RAM Modules.
By doing this we can check if the issue is due to the RAM Modules in the Computer.
If the issue still persists, then it might be due to any other Hardware component such as CMOS, BIOS or even the Hard Drive etc.,
As the issue might be due to any Hardware component, it would be better to get the Unit examined at the authorized Service Center.
Hope this helps.
Please feel free to contact for further information and assistance.
10/23/2010 10:34:52 AM • Dell Vostro 1000... • Answered on Oct 23, 2010
Dell Vostro 1000 Laptop Logo
33 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
unlock facebook account
  • Computers & Internet
