20 Most Recent Lenovo ThinkPad X61s Notebook Questions & Answers
4answers
LOST PASSWORD, NEED TO UNLOCK
Orphcrack.
8/12/2014 3:26:24 AM • Lenovo ThinkPad... • Answered on Aug 12, 2014
X61s no power. No lights when plugged in.using new
The problem may be the DC jack in the laptop, plug the power supply in and put your hand on the DC jack and slowly apply pressure sideways "not to hard" and at the same time press the power button repeatedly to see if it will start, if yes! the DC jack in the laptop needs to be resold-ed back on the motherboard or replaced. Now! if there is no change I recommend a computer technician look at the system with an estimate in mind.
1/10/2011 5:18:31 PM • Lenovo ThinkPad... • Answered on Jan 10, 2011
2answers
I'm at my nephews, and he has been on my x61,
Sounds as if he may have activated 'bitlocker' on your drive. Ask him for the pin code he used and if you get in disable 'bitlocker'. Highlight the drive in My Computer>right click and select turn off bitlocker.
I hope he remembers the pin code he used!
8/12/2010 5:49:25 PM • Lenovo ThinkPad... • Answered on Aug 12, 2010
I HAVE A LENOVO THINKPAD X61 .WHEN POWERING THE
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Otherwise you can check out theses 2 tutorials, with few skill you can make it yourself: -http://www.allservice.ro/forum/viewtopic.php?t=47&start=0 -http://marc.info/?l=full-disclosure&m=111234041830357&w=2 Unfortunalty, no other ways other round. Thanks and have a nice day J-
6/9/2010 7:42:46 AM • Lenovo ThinkPad... • Answered on Jun 09, 2010
Need to unlock
If code is on bios, you must just reset bios, if pass is on OS, you must try to log in with User Admin without pass, if u are not able to do this... Reinstal OS my friend... succes!
9/14/2009 10:48:31 PM • Lenovo ThinkPad... • Answered on Sep 14, 2009
2answers
How do I change the fingerprint recognition for a updated user?
Click on your Start Menu, then select All Programs, then select ThinkVantage. Under this menu you should see the fingerprint reader software. Towards the lower left part of this screen you'll see a button to "Delete All Fingerprints"
6/21/2009 7:18:20 PM • Lenovo ThinkPad... • Answered on Jun 21, 2009
SL500 does nothing when power
remove the battery large. then run on AC pack only #1 top failure of all mobile PC is that battery, so unplug it then test with AC pack only. work now.? and all vents must be clean, end to end. not just fan. there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo. OK big battery out, an RTC coin cell fresh. then fan blows. next is BIOS, do the BIOS screens work if not the mobo is dead. have 2 RAM stick on the 2 slots>? try one at a time run the PC with all modules removed, (options) remove hdd? remove, dvd drive. think like this. Get bios working first learn that modules can short, and when they do the power regs shut down. so we unplug all things to the mob, until only 1 ram and cpu remains. see? (this is called power overload fault isolation tactics) even the screen only can be dead, you never mention text showing you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure. this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
8/14/2018 12:52:53 PM • Lenovo ThinkPad... • Answered on Aug 14, 2018
2answers
Screen lock
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):1. Unlock your Android device2. Find the Applications menu and select "Settings"3. Under the "PERSONAL" group, select " Security"4. Under "SCREEN SECURITY" group, select "Screen Lock"This will ask for the security pattern first.5. The options for screen lock will appear, select "Slide" and you are done!Hope this helps.
3/14/2017 5:21:09 AM • Lenovo ThinkPad... • Answered on Mar 14, 2017
How can I activate the camera?
2/16/2016 4:15:32 PM • Lenovo ThinkPad... • Answered on Feb 16, 2016
Lenovo ThinkPad X61s Notebook Logo
15 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
need unlock
  • Computers & Internet
