20 Most Recent Kyocera FS-1118 Printer Questions & Answers
2answers
HOW CAN I RESOLVE ERROR c6000 in fs 1118
This might take some doing reseting the fs 1118 but it can be done if the fuser only got hit by a powersurge or overheated due to paperjam by the fuser...
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
press enter
enter 163 and then restart the copier...
sometimes you wont even be able to get to the service mode...
open the front of the copier and then execute the steps... the front meaning the area where you the toner is located...
trying keeping it open and do the steps...
if that fails then open it take out the toner drum cartridge and then put it back in...
then do the steps...
if it still doesn't take try it a couple more times...
if it still doesn't take.. buy a new fuser...
but it should take... it just takes a little experimentation... I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
9/5/2021 3:11:15 PM • Kyocera FS-1118... • Answered on Sep 05, 2021
What is the cause of error c3200 in a photocopying machine?
my dear you clean CCD camera and mirror
3/29/2018 8:38:18 AM • Kyocera FS-1118... • Answered on Mar 29, 2018
Kyocera FS1118, error code C6400, how do I resolve
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
9/23/2017 12:13:25 PM • Kyocera FS-1118... • Answered on Sep 23, 2017
How do I fix kyocera 1118 showing err a3 200?
scanner unit dusty please clean than solve problem
9/10/2016 6:19:03 PM • Kyocera FS-1118... • Answered on Sep 10, 2016
manual
What work Problem with Kyocera -1500 ERROR COD C6000
you chek heater unit and fouse
7/8/2015 7:17:46 PM • Kyocera FS-1118... • Answered on Jul 08, 2015
Error c3200
It means the exposure lamp is not turned on. Either a connector has come loose or the exposure lamp and/or the inverter pwb and/or the control pwb must be replaced
6/11/2014 4:07:15 PM • Kyocera FS-1118... • Answered on Jun 11, 2014
What do i do if u replace new toner and the message replace toner does go
Check the toner sensor under the processing unit (PU). Remove the PU and you will see in the front left side, inside the machine, a black sensor (a black part with cross screw on it and a spring underneath it. There is a possibility that sensor to be dirty or damaged. An important question is... is the toner original or compatible with appropriate chip (toner id)?
6/3/2014 5:05:47 PM • Kyocera FS-1118... • Answered on Jun 03, 2014
Resettare codice errore c6 su kyocera fs 1118
If the code is C6400, then just follow the procedure showing in the images below. If the code is C6000, then you have to remove the fuser unit and check the thermistor, the thermal cut out and the heater lamp. If are able to fix the problem-damage, then follow the procedure below to reset the service call. b6abe89e-6db1-403f-b1d5-10039126b726.jpg 6bbf89df-5e1f-4ba9-830e-5fa3e278ce55.jpg
6/3/2014 4:43:13 PM • Kyocera FS-1118... • Answered on Jun 03, 2014
Resettare errore c6
1-4-1 Maintenance mode The machine is equipped with a maintenance function which can be used to maintain and service the machine. (1) Executing a maintenance item Select Service setting using the up/down cursor keys. The selected maintenance item is run. Press the back key. Press the enter key. Start End The maintenance item is selected. Maintenance mode is exited. Maintenance mode is entered. Repeat the same maintenance item? Run another maintenance item? Turning power switch off and back on No No Yes Yes Select Maintenance mode using the up/down cursor keys. Enter the maintenance item number using the up/down keys. While pressing the start key and the # key, press the enter key. Press the system menu/counter key. Press the enter key. * The test print mode cannot be stopped until the preset number of sheets is printed. To stop the operation, remove the cassette to cause a paper empty state. To terminate the test print mode in the middle of operation, you must turn off the power switch and then on again to exit the maintenanc when in maintenance mode go to 163 to reset
5/9/2014 1:49:56 AM • Kyocera FS-1118... • Answered on May 09, 2014
ERROR COD C6000
Works with ERROR C6000, C6300, C6400 Switch off Open Toner Cover Switch on, holding "System Menu" Go to "Secure Setting" "Enter" Hold "Start" "#" "Enter" Scoll down to "Maintenance Mode" "Enter" Scoll down to "U163" Scoll do "Execute" "Enter" Close Toner Cover Leave run for a few seconds Switch off Switch on.... I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
5/4/2014 6:12:39 AM • Kyocera FS-1118... • Answered on May 04, 2014
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
5/4/2014 6:10:52 AM • Kyocera FS-1118... • Answered on May 04, 2014
0answers
0answers
0answers
Kyocera FS-1118 Printer Logo
59 questions posted
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
error c3200
  • Office Equipment & Supplies
