20 Most Recent
Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP TV Questions & Answers
How do I replace the Colour wheel
color wheel is relatively easy to replace. a few screws hold in place after removing cover, has 1 ribbon cable & one plug in cable, usually not difficult to unplug & re-plug new one, but keep fingers off the color wheel glass.
1/31/2015 9:19:12 PM •
Samsung...
Answered
on Jan 31, 2015
Colour wheel and lamp replaced on DLP tv,--lamp
first, the color wheel should not operate if the lamp does not come on; if YOU replaced the wheel yourself double check something.
There are two cables from the color wheel, one is a typical plug and the other is a flat ribbon cable, the ribbon cable has connections only on one side as it plugs in: it is very easy to plug it in backwards in which case lamp will NOT come on at all.
SD TECH
3/31/2011 3:41:23 PM •
Samsung...
Answered
on Mar 31, 2011
My Samsung 46in DLP turns
The blinking lights usually indicate that the lamp is faulty or burnt out. In this case a new lamp would be required. The lamp in your projector set should last around 3-4 years of typical use. If your lamp is at the end of it's life you may have noticed a gradual reduction in brightness over the last few months. In this case if it's still in warranty contact Samsung to arrange for a replacement lamp.
Occasionally the lamp may not come on even when it is not burnt out. You could try turning the power off for 60 seconds on the back of the set. The other possibility is that the lamp is loose. Refer to your manual on replacing the lamp and follow the instructions removing the lamp and then put it back into place. If neither of these work you will need to get a new lamp.
2/28/2011 9:46:08 PM •
Samsung...
Answered
on Feb 28, 2011
My dlp tv keeps switching itself off
take bulp vent cover off rear of tv. there is a little plastic switch that gets pressed in by this cover. i taped mine in because the cover wasnt pressing it in all the way and causing tv to shut off all the time. havent had a problem since.
11/8/2010 4:07:06 AM •
Samsung...
Answered
on Nov 08, 2010
Tv is making a loud buzzing noise and the picture
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
4/5/2010 3:49:05 PM •
Samsung...
Answered
on Apr 05, 2010
TURNS OFF ALL THE TIME
Hi
Thanks
for using FixYa. You’ll need to reset the Projection TV and to reset it follow
these steps:
- Turn off the television and
wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is
plugged into a power surge protector, remove it from there and plug it directly
into the wall outlet. Turn on the television. If the issue is resolved, then
the problem is with the power surge protector and not the television.
If the issue is not resolved then this might
have happened due to over-voltage. Please check the power supply unit for
swollen/bulged capacitors and burnt wires/components on the power supply board
of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and
unplug the TV for at least 1 hour (this will drain off current from
all components especially capacitors) before you perform any repairs. Also note
that the TV consists of very high voltages even when it is in OFF condition.
All this is only recommended if you have electrical expertise and know how to
solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for
further assistance.
Thanks
Rylee
1/28/2010 6:30:03 PM •
Samsung...
Answered
on Jan 28, 2010
Black line down lefthand side of screen about 1
The monitor is old. It could be slightly adjusted. But when you start getting lines, soon the image becomes blurry, and during CRT death the Cathode Ray Tube radiates 100 times the radiation of a healthy monitor.
1/6/2010 1:39:56 AM •
Samsung...
Answered
on Jan 06, 2010
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
Yesterday
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
