20 Most Recent
Sony NWZB135F MP3 Player Questions & Answers
Recover data from music drive
Hello
My
apologies if this message finds you long after posting this problem ,
but I am currently working through a backlog of problems that never got
answered and hopefully this info can still be of use if not now possibly
in future.
Please download Disc Digger HERE.
This is a free tool you can use that works very well and there is no
installation required, just run the program once you downloaded it.
Once
you have connected the memory disk / hdd to the computer , run the program.
On
the program , select the dig deep option for accidentally deleted files
or dig deeper for a formatted drive. Then select the disk you want to do
the recovery on and run the program.
The data will be displayed
and you can recover it from there. This will only work if the card has
not been used since the data was lost. Save the files to a location
on the computer hard drive and not back to the disk it is recovering from as this will
overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Malfunction
I had the same problem... did you realize which the solution was?
Hello, I have problem with
Try flashing the firmware of your mp3 player. Also press rest button while its connected to the computer for the driver to be reinstalled. hope this help.
My digital music player nwz-b135f give me boot
Please check and see if the player can be reset using the reset micro switch. If not connect to the PC and see if this is detected , if not the player memory can be corrupt, it is possible that there are corrupt files- virus- within the memory and so it is hanging up the player. You can download and scan for virus in your PC, now format and reload only with safe scanned files.Hope you check this out.
My walkman works but not
If your pc has windows xp sp2 or later and Windows Media Player 11,
please follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Thanks.
gylacz
Widowsxp does not connect NWZ
Please try these steps:
Thanks.
gylacz
