20 Most Recent
Nintendo DS Black Console Questions & Answers
Hello i brought my 7
I think you sould try to charge it up when you put it in and if it still doesnt come on just call the number on the back of the DS and it should have a number call that so they can restart the system.
Its saying that my WEP key is invalid but what im
Make sure that your router's WiFi security setting is actually set to WEP and not WPA or WPA2. WEP is the only encryption format compatible with the DS. You can access your router's security settings by going to http://192.168.1.1 in your browser. The username is usually admin and the password is usually blank. If that doesn't work, try it the other way around with the username blank and the password as admin.
Let me know if this works or not; if it doesn't I'm sure there are other things we can try. I was in a similar situation about a year ago and I had to do something much more complicated to fix it. Hopefully it won't come to that for you.
I cant get my dsi to play games with r4 card,,even had r4 card downloaded with new games
The DSi has several system updates specifically designed to block flashcarts such as the R4. Check the R4 website to see if they have information on what to do if your DSi has blocked the cart. You might be able to do an update to the R4 to fix it. Another option is to get a different cart that has a work-around built in, such as the "SuperCard DSTwo" which has a small chip inside it that other carts don't have and has a file you can download directly onto the memory card that goes into the cart to update it whenever that happens.
What is the wep key?
A WEP key is a password on your router or that is on your router used to protect others from accessing your internet and a password is requires to access it
0000fefe
HAHAHAHAHAhaHHAHAHAfjeaiajfiu!
No idea what you mean.
Nintendo dsi shut off
I'm going to say your Ds is damaged from the water and has finally decided to putter out and fail. Unfortunately I think your only option is to get a new handheld. Sorry man.
