20 Most Recent
LG Sprint Fusic LX550 Cellular Phone Questions & Answers
Screen is faded to white and barely ledgible...
There is nothing wrong with your screen, the problem is
from the flex that connects your screen to the phone's main board. This
flex must have worn out that's why your screen is not displaying any
picture.
The problem is common with flip and slide phones. The
flex gets worn out as a result of constant opening and close of the flip
or slide phone.
I would urge you to replace the flex and I am
assuring you that your screen will display picture again. You might also
be lucky to find out that the flex is not well fix, that is, it may
have loosed contact.
If you cannot change the flex yourself,
maybe you should take the phone to a local repairer within your
vicinity, so that the flex can be fixed/replaced.
Take care.
Charging
Have you try to use a similar charger to charge the phone to see if it will charge, if you have and yet, he phone is not still charging, the problem is the charging port on the phone, you will need to replace the charging port on the phone because it is bad and can no longer charge your phone.
Go to any local phone repairer to help you replace the charging port on your phone, this will cost you less than $4 to get it replace.
Take care.
Phone is not powering up
this is a device issue, or battery problem, you can take it to a service and repair center and they can look at the device for no fee if you have insurence
How to unlock a fusic
My friend you cannot use the LG Fusic to a T-mobile network since your phone is a CDMA phone & Tmobile is in a GSM network.
95% of all CDMA phones doesn't support a sim card & the remaining 5% that supports a simcard could only use the sim card from it's original CDMA provider.
GSM phones are phones that supports a sim card.
Hope that'll help you..
Happy Holidays...
**please rate my post**
I am not receiving picture mail, and picture mail
First contact your phone carrier and see if your messaging is on.
If they say everything is ok then its the phone. You can power down the phone ,remove battery, then replace and try it again.
Post back if this does not help or you get any errors.
Lg memory card error
well first of all you can try to format your memory card -
first of all you can try with formating card with your phone -
Format card in Phone, by going to Settings & Tools menu, option 8, Memory, Option 3, Card Memory, select options, with the right soft key, select.
if further you have the same problem then you can try to format your card using a computer, please follow the below steps -
1. Insert your memory card into your computer's reader if you have one.
2. Open up 'My Computer'. You should see it under the list of available drives.
3. Check its contents first to make sure that you have the right drive.
4. In 'My Computer', right-click on the drive and choose 'Format'.
5. Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6. Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
(note. you lost all of the data by formating a card, so please make a backup of your data before formating it)
if further you have the same problem then you need to replace the memory card.
Please post comments for more help or information.
Good Luck!!
Thanks
