20 Most Recent Gardner Bender #GSW-22 Push Button Switch Questions & Answers
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
7/6/2017 1:00:53 AM • Gardner Bender... • Answered on Jul 06, 2017
GSW-22 wall button switch
120VAC/3A is the rating of the switch. You are probably installing the switch to control a 120 volt device. 3A is the amperage capacity of the switch, which is not much. If you are replacing a wall switch that controls lights, I would recommend replacing it with a standard toggle switch. They are rated for 15 and 20 amps. Those button switches are meant to be used to control single devices.
2/4/2015 3:01:18 AM • Gardner Bender... • Answered on Feb 04, 2015
I have a GSW 312 series shallow well pump. I am getting great water pressure from the pump, but 10ft from the pump I am only getting a small flow. What do I need to do, this pump normally works very w
When this happened to me, I discovered a small stone stuck in the end of the hose.. Never did figure out how I got a stone in my hose...
6/16/2014 2:43:22 PM • Gardner Bender... • Answered on Jun 16, 2014
I have a GSW 312 pump that has great pressure coming out of the pump but when I connect it to the pipe 20ft away only has a small flow with no pressure. What do I need to get the pressure back up. Thi
to get the pressure up you have to step down the dia of hose or look for leaks or obstrutions in the hose sounds like pump is going bad length rise in hose pump is working slower maybe something to look at new pump
6/6/2014 6:22:44 PM • Gardner Bender... • Answered on Jun 06, 2014
Gsw-22 nameplate data
It will handle a load of 6 amps when connected to 120 volts ac, or if connected to 240 volts ac, will only handle 3 amps load. Regardless of any rating on the switch, ALWAYS !!, SHUT POWER OF TO ANYTHING ELECTRICAL BEFORE WORKING ON IT.!! No hollering at you, just want it emphasized to be sure you stay safe, and alive. Look at what your powering with this switch for an amp rating on it. If amp rating is higher than switch is rated at, don't use it, in case of fire.
4/17/2010 12:24:56 AM • Gardner Bender... • Answered on Apr 17, 2010
Bought wrong switch GSW-23 convert to GSW 22
You could drive an inverter, you could drive a flip flop, You could pulse a relay.
3/1/2010 6:14:19 AM • Gardner Bender... • Answered on Mar 01, 2010
How to wire toggle switch
The wire that comes from the power source (the "hot" one) goes to one terminal screw, and the wire that goes out to the switched device goes to the other screw.
2/4/2015 1:57:15 AM • Gardner Bender... • Answered on Feb 04, 2015
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
Gardner Bender #GSW-22 Push Button Switch Logo
6 questions posted
Top Gardner Bender Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Gardner Bender Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gardner Bender Electrical Supplies
Most Popular Question
gsw 22 nameplate data
  • Electrical Supplies
