20 Most Recent
Poulan 2-Stroke Engine Oil - 24 Pack Questions & Answers
Will this work in my
Yes if what you have is a two stroke engine. If it is just follow the mixing instructions on the bottle for the proper ratio for your blower. The ratio is usually molded into the fuel cap on the blower.
Need to make 50:1 ratio
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
Her chee fun 50 scooter. when trying to accelerate
Assuming everything is back toether properly and was not the problem the frst place, remove the exhaust pipe to expose the exhaust ports to ensure they are not carbon block. Also check the exhaust it self for a spark arrestor screen that could hve been carbon fouled and clogged. Cannot free flow because of the problems noted above, you will not be able to run a two-stroke engine reliably.
Rational for gas and oil
to lubricate the engine. there is no crankcase oil.
no oil= no lubrication=dead engine in no time at all
Have Poulan BVM200VS 25cc gas
By luvcatzlotz on Sep 08, 2010
Have Poulan BVM200VS 25cc gas blower. It has compression, is getting fire and has fresh fuel mixture. Will not start. Any suggestions? It is less than 1 yr old.Answer: I have the same problem. Thats why the company is called Poulan.. Because thats what you do half the time when you own one. PULLON the starter cord...............
6/12/2011 2:45:15 AM •
Poulan...
Answered
on Jun 12, 2011
No gas getting to cylinder on coleman 1850
I have never worked on this specific model but I am sure it has a fuel filter that would be where to start. If it doesn't have a filter install one. Also if no filter disconect the fuel line at the carb. and see if there is fuel. It should allow fuel to freely flow out of it so becareful. Also make sure the fuel shut off valve is open. If there is no fuel coming out of the line at the carb you have a clogged line and need to clean the tank and line to remove the clogg. If you do have fuel the carb is your problem and will need to take apart and clean.
Have a great evening
5/6/2009 11:03:30 PM •
Poulan...
Answered
on May 06, 2009
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
