20 Most Recent Honda Reliance RV Parallel Kit Questions & Answers
How to remove tank on a honda eg5000cl generator
This is reasonably easy to do. Does the Generator run? Start the generator as it's running turn the fuel Petcock to the Off position. The generator should stall and stop running. This helps safely empty the fuel line and carburettor between the tank and the engine. Disconnect the fuel line from the petcock tap and plug the ends to stop dirt getting in. On each corner of the tank itself there should be a bolt going through the ribbed edge and a rubber spacer. remove these 4 bolts and the tank should lift up and out. On some generators you might have to remove some trim panels to make it easier. Refitting is the exact opposite of this.
1/28/2024 5:34:28 PM • Honda Electrical... • Answered on Jan 28, 2024
Honda2200 generator, bluetooth
Provides information about the generator's status, performance, and reminders. The app also allows you to turn the generator on and off remotely, monitor fuel levels, and set the Eco-Throttle mode. Connect Your Honda 2200i to Bluetooth - YouTube honda 2200 bluetooth pairing - Search (bing.com)
1/21/2024 10:49:37 PM • Honda Electrical... • Answered on Jan 21, 2024
2answers
Hi does anyone know or have a contact for parts for a Honda eg550 generator
You'll need allot of info from your unit...but ck here...https://www.megazip.net/zapchasti-dlya-generatorov/honda/eg550-12536/eg550-25744or try here...copy and paste.https://www.megazip.net/zapchasti-dlya-generatorov/honda/eg550-12536/eg550-25744/eg550-770365/fuel-tank-eg550-eg650-13411092
7/14/2023 10:02:16 PM • Honda Electrical... • Answered on Jul 14, 2023
2answers
No Spark On Ems 4500 Honda Generator
Check oil alert switch, ignition switch and connections.
5/17/2023 9:10:35 AM • Honda Electrical... • Answered on May 17, 2023
On a Honda eu2000 generator. Generator will start then shuts off because overload light comes on
check outlets and wiring for corrosion or short
12/31/2022 1:20:49 PM • Honda Electrical... • Answered on Dec 31, 2022
Honda EX5500 power output
It sounds like you are experiencing an issue with your ex5500 generator where the voltage and frequency are not within the correct range when the generator is running. Here are a few steps you can try to troubleshoot the issue:
  1. Check the load: Make sure that the load you are running on the generator is within its capacity. If the load is too high, it can cause the generator to run at a lower frequency and higher voltage.
  2. Check the fuel level: Make sure the fuel tank is full and that the fuel is fresh. If the fuel is stale or contaminated, it can cause the generator to run poorly.
  3. Check the spark plug: The spark plug is responsible for igniting the fuel in the engine. If the spark plug is dirty or worn out, it can cause the generator to run poorly. Clean or replace the spark plug as needed.
  4. Check the air filter: The air filter is responsible for cleaning the air that is drawn into the engine. If the air filter is dirty or clogged, it can restrict the flow of air to the engine and cause it to run poorly. Clean or replace the air filter as needed.
If none of these steps help resolve the issue, it may be necessary to have the generator checked by a professional. They can diagnose and repair any underlying issues that may be causing the generator to run poorly.
12/31/2022 10:09:19 AM • Honda Electrical... • Answered on Dec 31, 2022
I've a Honda eu3000is generator, new carb, new starter. It will electric crank but not start but I can pull start it.
it seems like your ignition switch may not be removing the ground while in the starting position try removing the ground wire from key switch if it turns over and start with key replace switch assy.
12/16/2022 4:25:15 AM • Honda Electrical... • Answered on Dec 16, 2022
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY... HONDA has a very sensitive self protection device Your oil pressure cut off switch could be responding to the WRONG OIL... DIRTY OIL... LOW OIL or WORSE... OVERFILLED Oil. Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf Honda Generators Generator Operation Honda Power Equipment Owners Manuals http://powerequipment.honda.com/generators/generator-operation#fuel Honda Generators Generator Operation http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
11/7/2022 12:00:36 AM • Honda Electrical... • Answered on Nov 07, 2022
Honda em5000sx generator runs too fast
it's possible that u may have a worn washer underneath the governor gear it's internal this washer wears due to lack of oil change 4800 is way too high for that engine to operate 38oo max parts are inexpensive although doing the job to repair it is another it's behind the front cover of engine you need washer slider and governor gear totl cost of parts under 30.00.
11/6/2022 11:47:44 PM • Honda Electrical... • Answered on Nov 06, 2022
2answers
Why won't my portable generator start?
Hi, if it was a copy-cat item, it might have been built with cheap parts. Please purchase the real item and you should not have these problems. I would also advise against trying to change a generator's parts because if you mess up, you could accidentally spray carbon-monoxide into your environment which can be deadly. Thank you.
10/12/2022 1:22:15 PM • Honda Electrical... • Answered on Oct 12, 2022
Code 08 in generator honda EM7000 IS What does mean?
Go to this site and down load a manual.
9/29/2022 9:43:55 PM • Honda Electrical... • Answered on Sep 29, 2022
Honda EG1400X generator produces power but after a short time smoke comes out of generator, seems like rotor is overheating. Is this an AVR problem?
There is a short circuit in your stator or rotor coils wires, coil wire insulation broken down, Try to get the stator or rotor rewired or replaced.
8/6/2022 7:09:43 AM • Honda Electrical... • Answered on Aug 06, 2022
Honda SUA 2300 generator surges at idle.
It probably has bad fuel that is a few years old. Check out the videos in the link. What causes a generator to surge at idle? Surging caused by fuel problems usually happens for one of three reasons: incorrect fuel, low fuel levels, or poor fuel quality. Most generators have specific fuel requirements and using any type of fuel outside of those parameters can cause operational issues, including surges. https://www.google.com/search?q=Honda+SUA+2300+generator+surges+at+idle ..
4/28/2022 4:30:53 PM • Honda Electrical... • Answered on Apr 28, 2022
Honda generator eu6500is overload
if you mean the gas engine starts and then dies, its not getting fuel fast enough, a screen or filter, if its the type you start then engage the generator and it dies, not sure,, also a lot them have an oil sensor,, the older ones went bad a lot..., the all go bad eventually, most of the time you can unplug them and it will run fine,,, the wire that is connected near the bottom of the crankcase and usually has a plastic plug within a couple inches, just unplug it and see if that fixes it.... those new sensors shouldn't be very expensive. those are the two top issues....plugged up fuel supply in the carb or the screen in the tank or a filter in between,, or the oil sensor is bad... the sensor idea is because you're inside the house and the generator is outside so you wont notice if it runs low on oil and the sensor will shut it off to save it from damage...
11/21/2021 6:07:13 AM • Honda Electrical... • Answered on Nov 21, 2021
2answers
Why won't my honda generator won't produce electricity but runs
Have you checked all your fuses and switches?
11/3/2021 2:37:49 AM • Honda Electrical... • Answered on Nov 03, 2021
2answers
I have honda EU3000is just start for 30 seconds
More often than not, you have some type of blockage or obstruction in the carburetor that is responsble for this type of problem. Removing the carburetor and disassembling so you can clean the metering passages is going to be the best solution. There are generaly two circuits on the carb. a high speed circuit and low speed circuit. Make sure all metering passages are clean for the carb. to work efficiently. Also make sure you fuel switch is "ON".
10/10/2021 10:14:22 AM • Honda Electrical... • Answered on Oct 10, 2021
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
8/21/2021 4:54:13 AM • Honda Electrical... • Answered on Aug 21, 2021
Have no output power on my pramac s5000 . Motor starts fine, flip CBS on, and motor surges a second.
Disconnect all loads before turning on breaker. Add one load at a time. Do not exceed generator capacity.
Comment below for further assistance.
6/18/2021 3:48:57 PM • Honda Electrical... • Answered on Jun 18, 2021
Honda generator EU65is. The overload indicator light will not shut off. Why?
It would normally show that you are drawing more power than the generator can supply. Videos in the link https://www.google.com/search?q=Honda+generator+EU65is+overload+indicator ..
4/18/2021 9:49:42 PM • Honda Electrical... • Answered on Apr 18, 2021
Honda Reliance RV Parallel Kit Logo
Popular Tags
0 questions posted
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
honda2200 generator bluetooth
  • Electrical Supplies
