20 Most Recent Winco 200-Amp Automatic Transfer Switch - 4WATS200-31R Questions & Answers
Winco PSS8000 Standby Generator won't start
This question is too vague to give you a good answer. But since it's coming up very high on Google searches, and I recently solved the same problem on the same generator, I thought I'd add a few notes here for others. In my case, the engine would take a lot of cranking before it would start, and eventually refused to start altogether. If your engine won't even crank, ignore the rest of this, you have a different problem (starter, battery, cables, or solenoid). I'm also going to assume that you've checked easy stuff like the fuel supply, spark plug wires attached, etc. The PSS8000 runs on propane or natural gas. If it's cranking for a while and not starting, you should smell gas (not gasoline, gas like the gas grill before you light it). If not, then you have a fuel problem. In my case, all the usual stuff was fine but still no start. The problem was: low compression caused by negative valve clearance. Apparently gaseous fuels wear valves and seats faster than gasoline -- as a result the valve clearance (which is supposed to be a small positive amount) is reduced so the valves are basically held open a tiny bit all the time. This causes several nasty problems, but in my case the main one was low compression. As a result of that, the engine had a hard time starting. So in addition to all of the usual stuff (plugs, spark, fuel, etc.) check your valve clearance -- you're supposed to do it every season anyway. On my engine the correct clearance is 0.004-0.006" for both intake and exhaust.
12/12/2016 2:25:25 PM • Winco 200-Amp... • Answered on Dec 12, 2016
2answers
My generator has stopped exercising, and I also
check battery
12/12/2016 2:06:25 PM • Winco 200-Amp... • Answered on Dec 12, 2016
Generator keeps running when power returns, can
hi
cr8dog,
Actually the manual and specs only says :
It doesn't have to do in turning off, you may need to do it Manually.
or have additional Circuits ( Magnetic Contactors and circuits ) to
do the things ( cutting and turning off the generator ).
Specify also what make and model the genset you are having
to give you more additional info, should you wish to have it
activated or test it manually.
Although some says it just like a thermostat inside the fridge.
but i don't, till i know the model and circuits involve.
4/29/2010 12:22:01 PM • Winco 200-Amp... • Answered on Apr 29, 2010
2answers
Prblem with ASCO ATS
This could be part of the normal behavior of the ATS. Many ATS are set up to allow the switch mechanism to sit in the "neutral" position for a time delay (as much as a minute) so that things like large motors, pumps, etc to wind down so that they don't get powered up at full speed. Here is how I would troubleshoot your ATS:
1) With the Commercial power on and the ATS in Normal, start the generator and make sure that the power at the Emergency terminals of the ATS is the correct voltage and frequency, if this is a 3 phase system also make sure that the phasing matches the commercial power side.
2) Turn the generator off, make sure it's in off not auto. Turn the commercial power off. Then manually operate the ATS transfer mechanism (there is usually a little handle for this), check continuity of the poles of the transfer mechanism to make sure that it's really making and breaking contacts where it's supposed to. While you're doing this you need to check the limit switches at both sides of the transfer mechanism, These switches are how the ATS controller "knows" what state the mechanism is in, they sometimes get out of mechanical adjustment and on rare occasions break and have to be replaced.
3) Once you've satisfied yourself that the transfer mechanism is operating correctly, set it to the Normal position and turn the commercial power on. Switch the generator into Auto so that the system is in it's Automatic mode. Find the manual for the ATS if possible and locate and record all of the adjustable time delays, I often write down the time values we want inside the door of the ATS.
4) With your stopwatch or sweep second hand wristwatch at the ready, start the Test function of the ATS and time out the various operating states as the system goes thru them. In general your ATS should do something like this:
a) You hit the test function, the system simulates a Commercial outage and begins a transfer sequence. On many systems there is an adjustable time that the Commercial power has to remain off for anything to happen, this is Time Delay Start.
b) The ATS closes the contact that tells the generator to start. Then it waits until it sees correct power at the Emergency terminals of the transfer mechanism. When correct Emergency power is available, the ATS controller fires the transfer mechanism to put it into its neutral position. After an adjustable time delay (Time Delay Neutral), the controller fires the mechanism again to put it into Emergency position. Some mechanisms aren't designed to do this "stopping in the middle" feature and so there is only the one action by the controller to get from Commercial to Emergency position, it's also worth noting that on mechanisms that can stay in the neutral position the delay could be 0 so the switch will transition as fast as it can.
c) The system is now suppling the load from the generator. Some ATS require you to interact with the test at this point to get back to the Automatic mode, read the fine manual. In any case there will be a delay from the time the ATS detects correct power at the Normal terminals until it starts the sequence to get back to Auto, this delay is called Time Delay Emergency to Normal. You want this time to be just long enough to keep from making false transfers, but not so long that you waste fuel, most places are something like 15 - 30 minutes.
d) If there was a delay in the neutral position going to Emergency, there ought to be one coming back to Normal. Keep in mind that this delay isn't about the source of power, it's about the load.
e) Once the switch is in the Normal position, the ATS should keep the generator running for a time (Time Delay Cooldown), to allow the prime mover (engine) to return to a safe to shut down condition. On small air cooled engines this can be 0, on very large diesel engines it can be as much as 30 minutes.
f) The system is back in Automatic mode waiting for a power fail.
5) If the ATS can perform a transfer test as above correctly, it should be able to operate just the same way during a real outage. One can and should be able to demonstrate this by operating a disconnect (switch, breaker, etc) at the Commercial power side of the ATS.
If your ATS doesn't pass the transfer test as above, look for (in order of probability)
Incorrect power from the generator.
Broken or missadjusted limit switches in the transfer mechanism.
A mechanically broken transfer mechanism.
A bad controller in the ATS.
Regards,
Carl
1/28/2010 2:58:51 PM • Winco 200-Amp... • Answered on Jan 28, 2010
Need to reset Timer...need help
Hi Dawn,
I'll ask the obvious question, Does the engine start and run every Thursday at 2:30pm (more or less) or not?
What I see in the field is that people notice the TOD clock on the timer is incorrect due to DST changeover and make a boo-boo while trying to correct it. You seem to have the right idea above so it's better to observe and see if the thing operates like we want rather than fix what might not be broken :-)
Generally speaking...
Generators have 3 switch positions, Off, Auto, and Manual. I think that's the switch on the left side of the panel you mention.
Timers have a Program, Run, and sometimes Override mode of operation. This would be that switch on the right side of the panel above. When in the "Run" mode almost all timers display the current Time Of Day somewhere, many blink the colons in the display to indicate that something is happening.
Let me know if you need further help,
Carl
4/7/2009 3:53:00 PM • Winco 200-Amp... • Answered on Apr 07, 2009
2answers
Winco TMT-DG4 what is replacement battery?
  • Battery is Replacable
  • #TMT-DG4 WINCO
4/24/2017 10:47:43 PM • Winco Electrical... • Answered on Apr 24, 2017
Coleman Powermate 6250/500 PM0545005 has power to just one side of the 120/240 outlet. the 120 volt outlets have none. Ran just fine onr week ago
The capacitor has no bearing as you have output on one leg. Take or have an electrician check the power from L1 to N and L2 to N right as it comes off the generator stator, before any breakers and receptacles. If you have no power still on one leg, the stator is bad. The rotor is fine as you indicate you have power on one leg, you may have lost one set of windings in sthe stator. Good Luck
2/28/2015 11:15:30 PM • Winco Electrical... • Answered on Feb 28, 2015
0answers
No ac output on a winco 9000 multi fuel home power
How long has the unit sat?After long periods the rotor loses it's residual magnetism and may have to be field flashed for a few seconds. Also check that the rotor slip rings are clean and shiney
11/17/2013 2:43:02 PM • Winco Electrical... • Answered on Nov 17, 2013
Lose of residual magnatism
I have not worked on this model, however other Wenco generators have a capacitor the retains a charge to aid in the beginning of the power cycle. Also diodes could be leaking. Simple check with meter but parts must be removed or isolated to properly test. Be sure to short leads of cap before testing. More information is available at WWW.wencogen.com.
12/5/2008 5:41:45 AM • Winco Electrical... • Answered on Dec 05, 2008
Winco 200-Amp Automatic Transfer Switch - 4WATS200-31R Logo
Popular Tags
6 questions posted
Top Winco Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you a Winco Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Winco Electrical Supplies
Most Popular Question
prblem asco ats
  • Electrical Supplies
