20 Most Recent Kohler 17 kW Emergency Power System - 17RES-L Questions & Answers
hi
there are number of factors to your problems in this instant might be wise to get an assessment carried out by an engineer before incurring further and costly repairs
Kohler 17 kW... | Answered on Jan 03, 2018
i think the propane regulator is controlled by engine vacuum pressure in a lot of gensets. when was the last time your valve clearances were checked? this is just a thought because if the valves are too tight it may not make the vacuum needed to open the regulator. not sure but its easy to check.
Kohler 17 kW... | Answered on Jul 08, 2017
You may have a fuel issue, check that first. Check WC pressure on regulator, check shut off solenoid. Do this first.
Kohler 17 kW... | Answered on Mar 02, 2015
Check rotor slip rings,brushes then rotor and stator for shorts
Kohler 17 kW... | Answered on Nov 27, 2013
depending on what accessories you get and the fuel type like gas diesel nat gas propane it can run a couple thousand dollars plus the install as well if city permits required it is hard to say hope this helps shop around and have it installed by someone you trust or certified bonded and insured so there is no risk of a home fire good luck.
Kohler 17 kW... | Answered on Aug 31, 2010
F refer to "field" of the motor. The stationary part of the motor. they are alternate positive and negative to generate the magnetic field for the rotation of the commutator, in turn generating the output.
Kohler 17 kW... | Answered on Apr 07, 2009
Six steps of start-up Shangchai generator set :
A.Unscrew the deflation screw on the fuel injection pump, use the fuel hand pump to remove the air in the fuel system, and fix the adjusting control handle on the throttle position of the suitable starting speed;
B.Pressthe generatorstart button to start the diesel engine. If the diesel engine can't start in 10 seconds (up to 15 seconds), it should wait for 1 minute before starting for the second time. If it can't start for three consecutive times, should check and find out the cause of the failure;
C.After diesel generator set start up, the no-load speed gradually increases to 1000-1200 r/min (note not to run at low speed for a long time). After the diesel engine is preheated, the speed is increased to the rated speed. When the outlet water temperature reaches 55 degrees Celsius and the oil temperature reaches 45 degrees Celsius, full load operation is allowed;
D.After starting the diesel engine, pay close attention to the reading of oil pressure gauge (2.5-3.5kg/C?in normal operation). If the oil pressure gauge does not indicate, stop immediately and check whether the ammeter has charge indication;
E.After the diesel generator set is put into normal operation, should observe the changes of water temperature, oil temperature and oil pressure at any time, and should handle the reading of power meter, frequency meter, ammeter and voltmeter in time if abnormalities are found;
F.When each instrument of the genset indicates normally, can turn on the load switch to send power to the load. With the change of load of the genset, if the frequency and voltage are not within the prescribed range, should adjust the frequency and voltage in time to maintain the rated value. It is strictly prohibited that the genset carry load at low speed, so as to avoid damage to the equipment.
Kohler... | Answered on Sep 30, 2019
contact the maker,
ask them,
or buy one off ebay, using facts above
there is no other way. (there is a parts list at most makers web sites,Valsi
omg first google hit.
http://www.valsi.com.mx/
Kohler... | Answered on Sep 17, 2019
Maybe you can contact the supplier who provide the generator for you. Or you can read manual operation of use.
In the future, if you plan to have a diesel generator set, welcome to contact us: https://www.dieselgeneratortech.com/generator-set/
Kohler... | Answered on Aug 31, 2019
Can you be more specific? what model Kohler is it, Model number KW etc.
Kohler... | Answered on Aug 30, 2019
Kohler 17 kW Emergency Power System - 17RES-L Logo
17 questions posted
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Electrical Supplies
Most Popular Question
problem kholer 17res generator
  • Electrical Supplies
