20 Most Recent
Delta 35 7670 8" Stacked Dado Set Questions & Answers
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Arbor bolt part no. 1347813
you can google your question or better
delta boss spindle sander arbor bolt
About 565,000 result (0.59 seconds)
Balboa hot tub wiring diagram
CAUTION: Electrical work and repairs can be dangerous, especially around water. There is a risk of shock or electrocution, which could result in serious injury or death. We strongly advise that hot tub electrical wiring be referred to a licensed electrician. Local code requirements for wiring vary and may differ from the educational examples on this web site. The local code regulations must be followed, with permits and inspections obtained. The installer should read and follow the hot tub owner's manual and associated electrical component owner's manuals and instructions.
Try this link: file:///C:/Documents%20and%20Settings/Gil/My%20Documents/Troubleshooting%20&%20Service%20Manual%20230V.pdf
