20 Most Recent
Coleman 36qt Xtreme Cooler Questions & Answers
Broken hinge Colman cooler
I have three colman coolers with broken hinges. I would like to find some new hinges to replace them . model # 6270 6273
Need a drian plug for 32 qt coleman cooler where
You're probably out of luck. Coolers are relatively inexpensive, so they don't usually make drain plugs. I broke mine off and the best solution was a shaved down wine cork. I put it on the inside and it worked great. Use the newer plastic style and it will hold up forever. Good luck Alley
Coleman hand rocker pump 2231 - seal is gone. Is there a way to repair? Are these still available?
For others, not the OP from ten years ago:
Search Amazon "JR Products 97025 Chrome Manual Water Faucet" and this might be the same mechanism and parts as your Coleman 2231 pump. I went to my local shop in Calgary (starts with an H and ends with obo's, fixya considers that word to be profanity so I can't use the name H*bo's) and they had them there for $39. I swapped the plunger, cork and cylinder from the new one into my Coleman 2231 and will keep the bits from the new one for possibly the other parts in it.
Need instructions for a col-1390 coleman tent?
The directions are on the actual tent bag. The trick to setting this tent up is to stake it down first. Then set up the center poles - you will need at least two people to do this. Once it is staked it will go up pretty fast.
