20 Most Recent
Bowflex Revolution Home Gym Questions & Answers
I put one the first
You should be able to take off the plates by turning them the opposite direction as putting them on. If you look at the plate you'll see the grooves that lock each one together. You just need to twist the plate you want off and twist it out of the grooves. Once out of the grooves it will turn back to normal, releasing the tension on the bands inside. You can then just slide it off the bar. The perm attached 5# plate tends to turn too. You need that one to be stationary. If you can't do it alone, have someone hold the perm 5# plate steady as you turn 'off' the additional plates.
1/27/2022 4:29:30 PM •
Bowflex...
Answered
on Jan 27, 2022
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
4/19/2020 3:23:55 PM •
Bowflex...
Answered
on Apr 19, 2020
How to assemble bowflex extreme
The original assembly manual is available directly from the manufacturer at bowflexcatalog.com, there is a product manual link near the bottom of the page.
11/25/2014 8:44:55 PM •
Bowflex...
Answered
on Nov 25, 2014
How do I fold the bowflex revolution
There is a pop pin on the support at the end of the seat rail that must be pulled out to fold a Revolution up. You might want to download the complete operation manual, it is available directly from the manufacturer at bowflexcatalog.com. The product manual link is at the bottom of the page.
11/25/2014 8:41:44 PM •
Bowflex...
Answered
on Nov 25, 2014
Bowflex sport manual
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to
provide you with a real solution at this time.
Hopefully one of other experts will be able to
provide you with a real solution.
Thank you for using FixYa
2/13/2012 9:14:29 PM •
Bowflex...
Answered
on Feb 13, 2012
CANNOT RAISE OR LOWER RIGHT
Hello
Read the instructions. This may seem obvious but many of the problems that occur when putting together a Bowflex happen because directions are ignored or only referred to casually. Read each step completely
Loosen hardware. In some cases, problems can occur if you have made some of the hardware tight before it should be. The manual will instruct those working on the construction of the machine when they should and should not tighten bolts completely. Reading the manual completely will help you know when bolts should and should not be completely tightened.
6/20/2011 2:15:30 PM •
Bowflex...
Answered
on Jun 20, 2011
