20 Most Recent
Peg Perego Vespa Scooter Questions & Answers
Throttle cable slack on piaggio et2
To adjust the throttle cable slack on a Piaggio ET2, you will need to locate the throttle cable adjuster. The adjuster is typically located near the carburetor or the throttle body.
To adjust the slack, first loosen the locknut that secures the adjuster. Then, turn the adjuster clockwise to tighten the cable or counterclockwise to loosen it until the desired slack is achieved.
Once you have adjusted the cable, tighten the locknut to secure the adjuster in place. Be sure to test the throttle to make sure it is functioning properly before riding the scooter.
Fuel leaking from carburetor
Could be worn or sticking float valve, located in bowl of carburetor. to test turn off fuel, remove bowl from carburetor, gently raise floats all the way with finger, turn on fuel, it should not leak until released.
Trouble starting my vespa
check your takn and clean your fuel and air filter and check the fuel line from the tank to the carb and blow it out, 1 of these should help.
My 1962 Vespa GS 160
incorrect float level setting
needle and seat not properly installed
try having the carby professionally overhauled
Hi i have an lml sensation and the plug keeps
Hey June, the correct assembly. cleaning. setting, and adjustments of the carburetor are CRITICAL....Please take the carb to a qualified professional to get it cleaned and set. Ask him which screw sets the idle speed..and you can set it when you reassemble it.. (ONLY adjust the idle speed screw!!)
IF this machine has oil injection, and its been working fine.. do not adjust it...AND .. if the oil is injected into the carb (i've seen one or two bikes with this set-up)..its working fine..the fuel/air will be taken care of when the carb is fixed! Make sure your air filter is clean!!.. and a new spark plug will help!!
Vespa gt 125 - I bought it yesterday, road tested
might be the wrong key - try the brown colored master key (not black or blue)
teste-o4bn0faalxcoa4vjv5kzyzff-3-0.jpg" alt="vespa-gt-125-bought-yesterday-road-teste-o4bn0faalxcoa4vjv5kzyzff-3-0.jpg" />
