20 Most Recent
Hitachi NT65MA3 2 1/2 Inch 15 Gauge Finish Nailer Questions & Answers
Will the nt65ma3 use fn style finish nails
(fn) stands for finish nail,,, and there are different types of those,, this hitachi will use 15 guage, angle finish nails,, do not attempt to put 16 gauage strait or 16 guage angle nails in this gun,
Hi, I have been stumped! I rebuilt a Hitachi
This is the Cars and Trucks section of Fixya. You might get more answers listing in another area of Fixya which more closely matches your device.All things considered, maybe apply air pressure and stick the unit under water in a utility sink or big wash tub. Air leaks would bubble like a hole in a tire tube.
Hitachi nailer doesn't fire, it has no leaks. When trigger is pulled there is no back pressure from trigger
I've had that happen before and what I found was one of the Staples or nails had misfired and wedged before leaving the gun. read the manual on how to get to it for that particular model and also it might be a good idea to adjust your pressure accordingly to keep it from happening again. If the force isn't set proper then a nail could Jam , block the mouth and not allow any other nails to exit. It's very easy to do and not that hard to fix once you've done it at least once. Good luck.
My hitachi nt50ae2 will not work when I try to use 2 nails.
1) Oil it per the operating instructions.
2) Use only high-quality fasteners. I recommend Hitachi or Bostitch, although those from Harbor Freight Tools are largely trouble-free.
3) Make sure nails are properly inserted in the gun.
4) Check to confirm that your gun is receiving adequate air pressure. With that nailer, I'd suggest 95-105 psi.
