20 Most Recent
Milwaukee Tool Milwaukee 7100 - 20 3 - 1/2" Round Head Framing Nailer Questions & Answers
Truck runs for about ten to fifeteen minutes then
This is posted in a category that doesn't allow me to see what the year, make, and model of the truck is, but I know of none that have a sensor that shuts the engine off if there is a bad head gasket. One possibility is that the ignition module is going bad and as the engine warms up it malfunctions. Other sensors can do this too. Without more information on the truck I can't help you more.
Nail compatibility with Milwaukee framing nailer
any full round head with a 22 degree angle and plastic collated nail between 2 to 3 1/2 inch should work, they don't list any other specific brand but these are the requirements for the tool.
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
