20 Most Recent
Hitachi NR90AE Full Round Head Framing Nailer Questions & Answers
The piston slipped out of the housing-how do I install that?
The piston is broken if it came out.
Remove the 4 bolts on the head, remove head and you will see the piston - be careful removing it because it is easy to score the cylinder walls if it is cockeyed.
Replace the driver, lubricate the O-ring before inserting
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nail jamed in Nr90AD model heard their is a
I have the same nailer and I got a nail jammed in it when I hit a piece of metal.
I had to take the magazine off then remove the safety. This can be done with a hex key and a small wrench. Onece I had access to the nail head I banged it out with a hammer and small punch. It all depends on how and where its jammed, hopefully you don't have to take it apart and can just pull it out with pliars.
I own a hitachi nr90ac3 framing nailer and i
Oil leaking out of the nailer anywhere is just an indication that too much oil is being introduced. A good solution would be to reduce the amount of drops until no more leaks out or use an in line oiler at the gun. An oiler costs under ten dollars and feeds in oil vapor as you use air. Store / hang your nailer with the air inlet down at night to drain out access oil. Do not worry too much about the leaking though, I think that a bit too much oil is better than a lack of oil. Good luck.
