20 Most Recent Stanley Bostitch F21PL Nailer Questions & Answers
2answers
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
11/20/2018 12:19:51 PM • Stanley Bostitch... • Answered on Nov 20, 2018
I have a new Bostitch F21PL framing nail gun. I
when you removed the jammed nail did the piston driver move back into the rear position? if not there may still be a piece of the nail holding the piston.... If the piston is stuck in the forward position with the air disconnected use a hinge punch and tap it back, reconnect air and give it a try
10/10/2015 3:35:42 AM • Stanley Bostitch... • Answered on Oct 10, 2015
Jammed
use driver or nail punch and hammer to remove nail jam
7/14/2014 4:57:23 PM • Stanley Bostitch... • Answered on Jul 14, 2014
Bostitch f21pl air leaking out exhaust
Usually, air leaking from head is caused by worn/ broken seal # 163823 that sits on top of the cylinder. Remove head and observe seal. If it looks complete, however it fits loosly on the cylinder, use rtv sealeant under seal. Otherwise replace. Good luck
10/20/2012 6:01:36 PM • Stanley Bostitch... • Answered on Oct 20, 2012
How do you remove the front hub to remove the
If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
11/1/2011 8:13:41 PM • Stanley Bostitch... • Answered on Nov 01, 2011
My Bostitch F21PL Round Head nail g few times then
Examine all the parts in the head where orings make contact. Fine scratches on metal or plastic parts where orings contact will cause the problem that you describe. Plastic parts and aluminum will scratch easily causing air to leak past. The gun works after cleaning because the oil or paste that you used is making seal. Once oil is displaced, pressure leaks past. Remove fine scratches with 400 grit paper until very smooth or replace scratched parts. Vinyl seals that snap into place must fit very snugly. If vinyl seals turn easily, remove them and clean off oil, then apply RTV sealeant and re-install (let RTV dry for 24 hours before retest). If aluminum parts have a rather deep groove where orings make contact, replace because oring will no longer make good contact(you could try wrapping oring groove with teflon tape then install oring, this wil bring out oring a bit). Good luck
9/26/2011 2:56:11 AM • Stanley Bostitch... • Answered on Sep 26, 2011
Leaking air out the exhaust even after rebuild kit
I would suggest checking the cylinder seal and the firing valve for the problem. Also when you take the cap back off check for cut o rings in the cap assembly.
4/13/2011 2:03:00 PM • Stanley Bostitch... • Answered on Apr 13, 2011
I have a n80sb have
forget the out side trigger levers,you need the trigger valve assembly,its inexpensive go to your nearest bostich dealer
12/29/2010 12:09:13 AM • Stanley Bostitch... • Answered on Dec 29, 2010
How do I fix air coming out of the trigger? and
you can fix yourself if you have a small pin punch. You will need to get a new trigger assembly, the o ring in the valve has split in half. To replace and follow closely, first disconnect air line, take the pin punch and drive out the pin holding the trigger itself and then drive out the pins holding the trigger valve in place. Now and do exactly as written, find a shop rag or cloth put under the trigger valve and hold it. While holding the collar back on the quick disconnect push the air supply onto the fitting and the valve will "pop" out. when replacing the valve use a light coat of grease and align the slots in valve with the holes where the roll pins go, reinsert and you should be ready to go.
11/9/2010 10:16:19 PM • Stanley Bostitch... • Answered on Nov 09, 2010
Bostitch F21PL nailer is leaking air out of the
could be the firing valve is sutck or has a pinched o ring or the cylinder seal is extremely loose or pitted.
10/26/2010 2:03:32 AM • Stanley Bostitch... • Answered on Oct 26, 2010
Hi, got a bostitch N80
The rebuild kit # ( ork11) is available on ebay or here:
http://www.mendingshed.com/ork11.html
This kit may not have all the orings but does include other parts needed. There are other kits available on ebay that would include all the orings but missing other parts.
Sometimes all you need is to open gun and clean orings and contact surfaces and lube with silicone paste (sold at Lowes in the plumbing department used to lube faucet orings). The cylinder seal on top of the cylinder and orings at cylinder spacer is usually cause of leak at nose of gun. Good luck
10/6/2010 7:17:18 PM • Stanley Bostitch... • Answered on Oct 06, 2010
Using recommended 3 1/2" nails;
remove the nails and air hose. tap the gun lightly and does the driver fall down?? if so it needs new o rings and doesn't have enough seal to drive the nail. also look at the condition of the driver. FOLLOW CLOSELY, reconnect the gun and remove the nails pull back on the follower and using a piece of wood to activate the safety hold gun at an angle, weara safety glasses and depress and hold trigger to expose the driver, does it extend past the nose and LOOK DONT TOUCH to check the condition of the end. release the trigger. this should give you some ideas why. also recheck the nails for proper collation and head are they clipped or full round. Let me know and I will try and help further. READ closely before attempting the above ideas.
8/26/2010 3:07:40 PM • Stanley Bostitch... • Answered on Aug 26, 2010
How do i get stuck nails out of a bostich nailer
This would depend upon where the nail is stuck. Click on the link below to get to a site that has the complete diagrams of the unit. Enter the model number and you will get the diagrams with part numbers and costs should you need parts.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CPalnuStwKMCFUWC5Qod0XDcZw
8/17/2010 11:01:20 AM • Stanley Bostitch... • Answered on Aug 17, 2010
The air pressure won't pump
Can you provide more details about what is happening here? The gun does not "pump" anything. Is the plunger not working or retracting? Is the trigger failing to work properly or is there air leaking fro the gun somewhere? Please provide some details so we can help,
Thanks,
Dan
8/14/2010 12:23:33 PM • Stanley Bostitch... • Answered on Aug 14, 2010
Stanley Bostitch F21PL Nailer Logo
Popular Tags
44 questions posted
Top Stanley Air Tools & Compressors Experts
john h
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Air Tools & Compressors
Most Popular Question
bostitch sb 16 finish nailer
  • Air Tools & Compressors
