20 Most Recent
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Questions & Answers
Craftsman Zeroturn deck mows unevenly??
u should get on flat surface an loosen guides bolts let it drop all the way down then tighten ur guide bolds an that should solve problem u can make sure none of ur pins are wore but they can usually ware almost all the way through and still not make it cut bad now before u adjust the deck check blade they have been known to cut bad if wore or bent
How to remove assembly engine pulley
Depends on what pulley you are referring to. The bottom pulley is held in place by a large nut, the pulley has a key way to keep it from spinning. Sometimes this keyway will shear off if you hit something with the mower. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
No result when i turn the key. Battery is charged....
Make sure the brake is set, and the two 'power' handles are centered, i.e., in neutral position. Both of these have an interlock switch that prevents the mower from being started. Good luck! Please rate if helpful, thanks.
