20 Most Recent
Arrow T50 Staple Gun Tacker Questions & Answers
I need instructions on how to refill the Arrow T50
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Rosetto tacker RT12. Vintage?
Are there commom staples to arrow etc.?
looks like an old bostitch stapler I used and that used generic staples that were a common item for staplers
all you have to be careful of is the width of the staples in use as some do not slide easily in the rail if they are not made for that width rail in the stapler
prong length is of no matter as you can get different lengths for different materials
