20 Most Recent Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487 Questions & Answers
Northern tool brand wire fed gasless welder feeds wire fan work no welding?
You need to have the ground attached to what you'll be welding on. Make sure there isn't anything on the end of your wire. Also, if your voltage is all the way down it won't do anything either. Oh, one more thing, make sure you have a contact tip on the end inside the cone. That will be the copper thing the wire goes through with a really small hole. I know some of this sounds pretty obvious but if I hadn't done these things at least once.....I wouldn't know what to look at either. I also don't know your experience level and want to cover all avenues. Hope you find it!
12/28/2013 3:02:43 AM • Hobart Handler... • Answered on Dec 28, 2013
Spool won't turn
are the rollers tightened enough, also maybe the wire is jammed in gun.
2/3/2013 10:04:27 PM • Hobart Handler... • Answered on Feb 03, 2013
0answers
Got a hobart handler dont
Serial number does not come up as a valid one. Check again.
8/5/2011 6:49:24 PM • Hobart Handler... • Answered on Aug 05, 2011
0answers
My welder feeds normal for the first 10 to 20 secs
Depending on how old you machine is, its possible that the wire feed rollers are worn causing the wire to slip in the grooves. Replacing the WFRs may solve the problem. Test this by watching the feed rollers as you pull the torch trigger, place a gloved hand over the nozzle as the wire comes out and watch to see if the rollers slip on the wire when the wire meets the resistance of the glove. If it does that likely the problem. Hope this solves the problem.
6/20/2011 7:05:47 PM • Hobart Handler... • Answered on Jun 20, 2011
Trying to find out what
Can't help you with the year,but here's the owner's manual. The serial number should be a combination of two letter and six numbers, like: KK123456. The one you are posting it's not a serial number.
http://www.hobartwelders.com/om/0900/o947h_hob.pdf
Hope this help you. ; ).
3/7/2011 8:54:19 PM • Hobart Handler... • Answered on Mar 07, 2011
My hobart handeler 125 will not stop feeding after
The trigger is bad in the gun. It sound like the spring is bad, or you have some junk in the trigger not alowing it to release. Remove and inspect/clean the trigger. If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
11/7/2010 5:44:18 AM • Hobart Handler... • Answered on Nov 07, 2010
Where can i get parts for my hobart welding
Your local welding shop supply will be able to give you advice, the guys at Lowes and farm supply shops just sell the welders
10/5/2010 9:27:03 PM • Hobart Handler... • Answered on Oct 05, 2010
My fm140a will not feed wire
You may need to adjust the tension just in front of the wire spool
Your gun liner maybe shot
3/8/2010 11:58:58 PM • Hobart Handler... • Answered on Mar 08, 2010
My wire dont feed out some time when i pull the
Inside your machine just in front of the wire spool is an adjustment to increase the tension on the wire tighten it a little bit at a time until your wire feeds
3/8/2010 11:56:41 PM • Hobart Handler... • Answered on Mar 08, 2010
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
12/24/2009 1:56:14 AM • Hobart Handler... • Answered on Dec 24, 2009
Wire feed motor not working
I believe the circuit card assembly has failed. It is very rare that the motor is the problem.
11/7/2009 11:15:16 PM • Hobart Handler... • Answered on Nov 07, 2009
SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
3/1/2009 10:17:32 PM • Hobart Handler... • Answered on Mar 01, 2009
Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487 Logo
Popular Tags
28 questions posted
Top Hobart Welding Tools Experts
Sean Wright
Sean Wright
oneStan
oneStan
Kardoc
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Hobart Welding Tools
Most Popular Question
  • Welding Tools
