20 Most Recent
Dremel 300 N/55 300 Series 1.15 Amp 5,000 To 35,000 Rpm Variable Speed Rotary Tool With 55 Accessories Questions & Answers
Dremel keeps turing off when moving it.
It's probably the cord, they usually fail right where they cord meets the tool. Experiment a little by bending the cord in this area slightly as it is running. If that confirms it, buy an extension cord of a similar size, and cut off the female end. You can re-use the strain relief (that's a rubber boot or coiled spring in the area of the failure). Carefully disassemble the dremel - taking pictures as you go. I assume you can solder.
good luck,
Al K
I need a replacement part
toolsforless.com is showing this part# to be currently in stock, the description matches your dremel model # as well.
Looking for the service manual for a weller mini shop model 601 Dremel tool
I'm sorry, but I don't have access to specific service manuals for individual tools. However, here are some steps you can follow to find a service manual for your Weller Mini Shop Model 601 Dremel tool:
- Visit the Weller website: The Weller website may have a library of manuals for its products, including the Mini Shop Model 601.
- Check the manufacturer's support page: Most manufacturers have a support page on their website where you can find user manuals, FAQs, and other resources.
- Search online: You can also try searching online for a digital copy of the manual. Websites like ManualsLib and ManualsOnline may have the manual you need.
- Contact the manufacturer: If you're unable to find the manual online, you can contact the manufacturer directly and request a copy. You may need to provide your tool's model number and other information.
I hope this helps you find the service manual for your Weller Mini Shop Model 601 Dremel tool.
My Dremel nut is stuck can't get off looks like it is stripped
If the threads on the nut or shaft are stripped, the nut will turn freely and it can be removed with pliers by turning and pulling at the same time. If it won't turn, it is probably galled or cross-threaded. In that case, try penetrating oil first. If that doesn't loosen it, try heating the nut with a butane or mapp gas torch. Good luck.
How do you assemble a dremel flex shaft 225-01
You screw off the collar on the tool, remove the chuck and inner part. The chuck is replaced with a special chuck (no inner piece). The special chuck has a square opening in it's nose that accepts the square end of the flex shaft inner cable. Is is actually a speedometer drive cable, from yesteryear.
Then you pull the inner cable out slightly, if it will, and put the inner cable into the square opening of the special chuck on your dremel motor. once engauged, you carefully screw the outer shaft housing on to the end of your dremel motor.
What you want to avoid is damaging this area during flex shaft assembly. I have had success with turning the output side of the flex shaft, while tightening the outer flex shaft onto the dremel motor. Stop tightening if it starts binding...
Rotation seems to help with alignment of all parts.
Cheers,
Doc
