20 Most Recent Coleman Powermate 5000W Home Backup Generator #PM0435 Questions & Answers
3answers
Y generator starts but not putting out any power
plug in a electric drill into the generator. start the generator and let it idle. depress the trigger on the drill with the drill set in the forward position and by hand turn the drill in the opposite direction. it should excite the generator and start the drill
8/6/2013 12:53:57 AM • Coleman... • Answered on Aug 06, 2013
You not getting any spark going to your spark plug
Please check : - your coil for malfunction and - power supply goes to your coil.
regards, jay
2/21/2011 6:58:11 PM • Coleman... • Answered on Feb 21, 2011
Generac 5500XL, model#09778-7 no output. Changed
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
2/3/2011 6:11:41 PM • Coleman... • Answered on Feb 03, 2011
2answers
How do I plugnit into circuit?
Not sure what you mean by "plugnit into circuit"
This is a stand alone unit into which you plug the devices that you wish to power. It should have standard recepticls for your devices.
If you are talking about attaching it to your residence, that will require a cutover switch that will disconnect the outside hydro source while the generator is plugged in. That's a job for a certified electrician.
2/1/2011 6:03:11 PM • Coleman... • Answered on Feb 01, 2011
0answers
No output from my generator
There is no such thing as "remagnatized" thats horrible and stupid advice. Your engine once started turns an alternator, which that produces electricity. Check all wiring connections first, if everything looks okay, you may need to replace the alternator.
8/9/2009 3:26:32 PM • Coleman... • Answered on Aug 09, 2009
Power cord hook up color code red white black
if your plug and outlet are 4 blade, two blades will be flat, the black will connect to one flat blade and the red will connect to the other flat blade,makes no differance to which,the white will connect to the middle blade with a silver color screw terminal,the others will always be brass in color!,the green will connect to the blade that is either "L" shaped or round.looking at the male plug from the blade side it looks like a crows foot,top left blade will be at 11 oclock,right blade will be at 1 oclock,these two are critical, one must be black the other must be red, center is white, other is green. good luck.
2/20/2009 6:21:39 AM • Coleman... • Answered on Feb 20, 2009
Coleman powermate starter pulley broken
Take the pulley to any auto parts store and they should be able to match it up. good luck.
1/26/2009 10:07:19 PM • Coleman... • Answered on Jan 26, 2009
PM0621512 15000W Coleman Generator not starting
An OVERCRANK fault implies no start after three attempts. Most likely a fuel issue.
11/25/2023 1:26:24 PM • Coleman... • Answered on Nov 25, 2023
I am looking for an owners manual for a Coleman gasoline powered 120/220 generator
Coleman is now Powermate.
https://www.powermate.com/generators/portable-generators
Post model number and likely someone will comment with a URL address of the manual.
11/2/2023 10:40:38 PM • Coleman... • Answered on Nov 02, 2023
Coleman Vertex 5500 Generator. Where is the starter solenoid on it please.
Question edited for clarity and spelling errors. Follow the heavy gauge positive wire from the battery. It is shown in the link. https://www.google.com/search?q=Coleman+Vertex+5500+Generator.+Where+is+the+starter+solenoid and https://www.google.com/search?q=coleman+vertex+5500+generator.+starter+solenoid+replacement ..
7/29/2023 5:46:15 PM • Coleman... • Answered on Jul 29, 2023
What is/would be the price for a replacement motor for a coleman powermate aircompresser
Not sure which unit you have as they make several. But here's some sites to check out.. https://www.google.com/search?q=coleman+powermate+air+compressor+motor
7/28/2023 6:45:22 PM • Coleman... • Answered on Jul 28, 2023
2answers
How to remove a rusty fuel tank for cleaning
When dealing with specific equipment like the Coleman Powermate Pro 6750 generator, it's important to follow proper procedures and consult the manual for disassembly instructions. However, I can provide some general guidance:
  1. Look for hidden screws or fasteners: Check for any additional screws or fasteners that may be securing the plastic control panel to the generator frame or the fuel tank. These may not be immediately visible or obvious.
  2. Disconnect electrical connections: Before attempting to remove the control panel, make sure to disconnect any electrical connections that may be attached to it. These could include wires or connectors for the generator's controls, switches, or displays.
  3. Release clips or tabs: Some control panels may have clips or tabs that hold them in place. Look for any release mechanisms that may need to be pressed or disengaged to remove the panel.
  4. Seek guidance from the manufacturer: If you don't have the manual or are unsure about the disassembly process, it's recommended to contact Coleman Powermate customer support or visit their website. They can provide you with the specific instructions or guide you through the steps needed to remove the control panel and access the fuel tank.
Remember to exercise caution and prioritize your safety when working with equipment like generators. If you are uncomfortable or uncertain about the process, it's best to seek professional assistance or consult a qualified technician to avoid any potential damage or harm.
6/18/2023 5:01:58 PM • Coleman... • Answered on Jun 18, 2023
Manual for Coleman Powermate Pro 6750 Generator model PM0606750
google coleman powermate pro 6750 manual copy and paste link https://manualsbrain.com/en/manuals/1408153/
6/17/2023 4:24:58 PM • Coleman... • Answered on Jun 17, 2023
Coleman pm1500 started it up plugged in extension cord to much load killed motor now getting no fire from engine
It sounds like your Coleman PM1500 generator may have experienced a serious issue due to overloading, which may have caused damage to the engine or electrical system. To troubleshoot the issue and restore power to the engine, you may want to try the following steps:
  1. Check the oil level and fuel level: Make sure that the oil level in the engine is sufficient and that the fuel tank is not empty.
  2. Check for any visible signs of damage: Check the generator's components, including the engine, spark plug, and electrical system, for any visible signs of damage or wear.
  3. Test the spark plug: Remove the spark plug and inspect it for damage or fouling. If it appears to be damaged or fouled, replace it with a new one.
  4. Check the electrical system: Use a multimeter to check the voltage output of the generator's electrical system. If the voltage is low or non-existent, there may be an issue with the generator's alternator or voltage regulator.
If you are unable to diagnose and fix the issue yourself, it may be best to take the generator to a qualified repair technician who can help you identify and address the problem.
3/19/2023 3:14:05 PM • Coleman... • Answered on Mar 19, 2023
2answers
Trying to wire in the outlets on my generator
power mate 8000 series.no model told or serialmoved this to generatorsask maker for help, or seller the GEN is country specific, none told.moved this post generators..
3/19/2023 3:11:02 PM • Coleman... • Answered on Mar 19, 2023
Coleman Powermate starts but dies after 10 seconds
It sounds like you've already done a lot of troubleshooting, but here are a few more things to check:
  1. Spark Plug: Check the spark plug for any visible damage or deposits, replace if needed. Make sure it is tightened properly and there is a strong spark when cranking the engine.
  2. Fuel Filter: Check the fuel filter for any clogs or debris, replace if needed.
  3. Air Filter: Check the air filter for any damage or clogs, replace if needed. A dirty air filter can restrict air flow to the engine and cause it to stall.
  4. Vacuum Leaks: Check for any vacuum leaks in the fuel system, this can cause the engine to run poorly and stall.
  5. Governor System: The governor system regulates the speed of the engine. If it's not functioning properly, the engine may stall. Check the governor arm, linkages, and springs for any damage or looseness.
  6. Ignition System: Check the ignition system, including the ignition coil and ignition module, for any signs of damage or wear. Replace if necessary.
  7. Fuel Pump: Check the fuel pump for proper operation, the fuel pump may be failing and not delivering enough fuel to the engine.
These are just a few possibilities, and it's best to consult the owner's manual or a professional mechanic to diagnose and repair the issue.
2/13/2023 5:53:52 AM • Coleman... • Answered on Feb 13, 2023
Coleman Powermate 5000W Home Backup Generator  #PM0435 Logo
13 questions posted
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Electrical Supplies
Most Popular Question
coleman powermate starter pulley broken
  • Electrical Supplies
