20 Most Recent
Thermasol Steam Bath Generators - Ambiance Pro - AMBPRO Questions & Answers
Thermasol Pro 150 - 25094.
yes thats correct or if you have manuel flush at the genrator there is a ball valve. open for minutes then close and run generator for thirty minutes without anyone in the shower.
The steam shower reads ttmpl
This is a temp sensor low or disconnected contact Thermasol at 800-776-0711 and our tech support team can help you out.
TIML light is on and nothing works
Please contact Thermasol tech support at 800-776-0711 and our techs can help you get your unit running if you call will model and serial number will be very helpful.
TTMPL code showing on my Signature series control panel. ???
I have a Thermasol steam generator which had the error code TTMPL and it had to be replaced by the manufacturer. From memory, the error code might stand for "tank temperature monitor pressure low" or something similar. As an aside, the replacement generator just started to show the same error message -- so now I'm two for two -- and not entirely happy.
