20 Most Recent Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor Questions & Answers
When cold compressor starts and fills up with air.
you may have a bad pressure switch:
Unplug the compressor. Drain the tank down to zero. Close the drain. Get down close to the pressure switch and have someone else plug the compressor back in while you are closely monitoring the pressure switch. Do you hear anything happen? Do you see any movement in the pressure switch.
by plugging it in with the tank at zero pressure, you should hear a click as the pressure switch trips due to low pressure. It should trip and send power to the electric motor. If this doesn't happen, you may have a pressure switch problem.
10/23/2013 9:14:13 PM • Ridgid 17038 4.5... • Answered on Oct 23, 2013
0answers
Air compresser comes up to pressure just fine but when demand call for it to kick on locks up. if you bleed it off to ) it will pump back up
if it's tripping the breaker it's pulling to many amps i have one that puulls 15 amps and you have to use 20 amp breaker.
8/19/2012 3:51:52 AM • Ridgid 17038 4.5... • Answered on Aug 19, 2012
I have the 45175A model
2 things to check, first, empty the air out and try running it, mine will not run or start when 1/2 full, too much back pressure, 2, mine will not run at all when cold, needs to be warmed up, we had a room on the job set up for the compressors to keep warm, I thought it was just mine, it was every-bodies. Check it out, Oh and 3, make sure you have enough power, If I can' t get 16 amps, it won't run, just hums, then kliks off. Don't use a cord if you can help it, if you do, make sure it is heavy wire.
1/18/2011 2:48:43 AM • Ridgid 17038 4.5... • Answered on Jan 18, 2011
My compressor will not turn off
check the pressure switch should be a little black cover with 1 screw holding it on it works the same as a water tank pressure switch contacts closed ON contacts open OFF or the pressure relief valve may be bad it is usually a couple off inches long and about the size of a quarter if it is open the compressor will not be able to build enough pressure too open the pressure switch
1/17/2011 12:23:54 PM • Ridgid 17038 4.5... • Answered on Jan 17, 2011
My compressor is not holding any air in the tank,
I would check all threaded fitting and tighten any that are loose. Make sure that tank drain does not have some rust or other debris that would stop it from closing completely. Check for any pinholes or cracks in air hoses.A easy way to find leaks on a air hose is to use large tub or bucket filled with water and run hose thru it and look for bubbles.
Also check o-rings on pressure reulator for any wear,and emergency blow down valve is soequipped.I hope this helps you some. Thank you
1/2/2011 3:18:17 AM • Ridgid 17038 4.5... • Answered on Jan 02, 2011
2answers
Ridgid air compressor OF45150A twin stack
sounds to me like u do not have it on a big enough circuit, look on the name plate for FLA, this is the amps it pulls to start up, and size ur circuit for that amount.
11/4/2010 9:01:22 PM • Ridgid 17038 4.5... • Answered on Nov 04, 2010
My gas powered compressure runs good as far as it
The regulator pressure spring may be broken. Does the regulator knob turn freely both ways, but the gage stays at zero? If so, you need to replace the regulator.
8/3/2010 3:22:41 PM • Ridgid 17038 4.5... • Answered on Aug 03, 2010
Bought a new pressure switch for the ridgid twin
You have to have a leak some where other than you compresser. check the lines and fitting s to you air tools.
5/5/2010 12:58:09 AM • Ridgid 17038 4.5... • Answered on May 05, 2010
GOT A NEW SWITCH DOES WHITE GO UPPER POST OR
Does'nt matter,a/c voltage does not care as it is alway"alternating the voltage" anyway.
4/18/2010 11:54:14 PM • Ridgid 17038 4.5... • Answered on Apr 18, 2010
Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor Logo
53 questions posted
Top Ridgid Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Ridgid Hammering Expert? Answer questions, earn points and help others
View Most Popular
Ridgid Hammering
  • Ridgid Hammering
Most Popular Question
  • Hammering
