20 Most Recent
Lisle Serpentine Belt Tool Questions & Answers
How do i take serpentine belt off 95 lesabe
Very simply, there should be a spring-loaded "idler pulley" that keep tension in the belt, locate that and figure out how to release tension, they are all slightly different. Important!!- Make sure you make a diagram of how the belt is on there, so the new one can be threaded properly.
The idler puller usually is one that is just there, not driving an AC pump or alternator, power steering pump, etc. Look for a square hole in the idler pulley itself or it's bracket that a socket wrench driver can fit into. Then slightly put pressure on the socket wrench handle and the pulley should move without too much effort.
I need a diagram to put my serpentine belt on my
Click on the following direct Link. It has several Diagrams for your Belts, based on your specific engine and options. These also include specific instructions on moving the Tensioner, in order for you to loosen and remove the Belt.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
Need to change serpentine belt
The tool is just a long wrench really. You turn the tensioner counter clockwise to release the tension. Take care to just turn enough to release enough tension to remove the belt. If you turn too far you will release the tensioner and the spring inside it.
Put the new belt in place running over the tensioner last. Then again release the tension with the tool in the same manner.
You do not need the special tool any wrench will do that can reach the tensioner.
