20 Most Recent
Dewalt DC330K XRP 18v cordless Jig Saw Kit with All - Metal Keyless Blade Change Questions & Answers
Blade comes out while sawing
I have used the same tool. Make sure that the blade release/ hold tab is engaged. Maybe the return spring is fouled or stuck. Try some lubricant.
Should i take apart Dewalt flexvolt battery after it was wet then in rice .
The battery is likely to be fine, but what about the electric motor in the saw, in rice as well? The only thing that tends to get damaged is electronic board components.
Rice only works well if it was warmed first, silica gel packs are better. A couple of days should be good, but my advice it open it up straight away and dry with a hairdryer or heat gun.
2/11/2023 1:42:41 AM •
Dewalt Saws
Answered
on Feb 11, 2023
DeWalt Flexivolt Mitre Saw.
It is likely that the trigger switch on your saw is faulty and not allowing power to flow to the motor. You may need to have the switch repaired or replaced by a professional. In the meantime, you may not be able to use your saw until the issue is resolved.
2/8/2023 6:19:57 PM •
Dewalt Saws
Answered
on Feb 08, 2023
Changing my blades on a DeWalt 735.
The cutterhead is now exposed. If the eight screws in
the cutterhead clamp are not visible, use a piece of
scrap wood to carefully rotate the cutterhead (Fig. S)
until the screws are accessible and the cutterhead lock
lever18engages. This will prevent further rotation of
the cutterhead as you change the knives
12/8/2022 8:54:53 PM •
Dewalt Saws
Answered
on Dec 08, 2022
