20 Most Recent
Little Giant 10 Cia, 1/2 Hp, 83 Gpm Automatic Submersible Sump Pump 10' Power Cord Questions & Answers
10E-CIA-sfs,
Impeller needs a push to
Sorry to tell you this but youre going to need to get a new one.
Try a place called "harbor freight" think you might like the prices as well as the fact they ship it really fast.
Just take a look at the online cat.
Good luck,Gary
Little giant model PEM-07. Caan electric cord be replaced??
Honestly I don't think so. If I remember the pump housing is ultrasonically sealed to prevent water entry and is not designed to permit opening for repair.
But there is another way.
If you can't replace the cord, cut off the bad section, leaving as much as you can that's still good; and wire it together with another waterproof extension cord through a water proof fountain repair cable kit. (Don't forget to use a water-resistant cable assembly or water will eventually migrate into the insulation, shorting the cable.)
Here's one example.
http://community.homedepot.com/howto/DiscussionDetail/Repair-Fountain-Cable-9065000000007sD
By all means, this pond circuit MUST be protected by a GFCI. Water, electricity and a human body don't mix well.
I have a Little Giant
No, The discharge check valve may be leaking and letting water drain back into tank. It is time buy a new one about $45.00
To: Tim Hofstetter
Its supposed to be controlled entirely by the float switch in the pit, etc. Its not uncommon for the pump to work or stay on even if the water level drops because the float can get hung up on the pipes, side walls, debris in the pit etc. You need to eliminate all those issues. Other issue is the float switch my be bad, hanging up or need resetting to the proper height etc. If its still a problem try replacing it with a water sensor switch instead.
