20 Most Recent
Little Giant Submersible Sump Pump 2760 Gph, 3/10 Hp, 1 1/2in., Model# 506158 Questions & Answers
My sump pump doesn't shut off, I am assuming it
These units are normally factory sealed. You can buy a secondary float switch from a hardware store which intercepts the pumps power at the wall outlet and takes over the float switch duty. compare the costs as it may be more benificail to replace the pump
Hi, my little giant 506158
For this pump to turn on, it must be under 7" to 10" of water. The water gets into the switch housing (which has an opening in it) and water pressure pushes on the rubber diaphragm (much the same as you did when you removed the cover). Once the pump turns on and lowers the water level to between 1" and 4", the pressure of the water will not be enough to keep the switch closed and the pump stops automatically.
Gary
Little giant model PEM-07. Caan electric cord be replaced??
Honestly I don't think so. If I remember the pump housing is ultrasonically sealed to prevent water entry and is not designed to permit opening for repair.
But there is another way.
If you can't replace the cord, cut off the bad section, leaving as much as you can that's still good; and wire it together with another waterproof extension cord through a water proof fountain repair cable kit. (Don't forget to use a water-resistant cable assembly or water will eventually migrate into the insulation, shorting the cable.)
Here's one example.
http://community.homedepot.com/howto/DiscussionDetail/Repair-Fountain-Cable-9065000000007sD
By all means, this pond circuit MUST be protected by a GFCI. Water, electricity and a human body don't mix well.
I have a Little Giant
No, The discharge check valve may be leaking and letting water drain back into tank. It is time buy a new one about $45.00
To: Tim Hofstetter
Its supposed to be controlled entirely by the float switch in the pit, etc. Its not uncommon for the pump to work or stay on even if the water level drops because the float can get hung up on the pipes, side walls, debris in the pit etc. You need to eliminate all those issues. Other issue is the float switch my be bad, hanging up or need resetting to the proper height etc. If its still a problem try replacing it with a water sensor switch instead.
Tim Hostetter
Do you have a check valve in the pipe going out to wherever you are pumping,? If not the water from a long run will just keep recycling in the basement and the pump will run continuously. Is your pump running all the time? If so of course you will wear it out. Add a check valve if you dont have one. you can buy one at any hardware store. Just tell them the size of your discharge line.
