The pump running will not hurt anything except that it takes a bit of electric to run it...
Now, is the t-stat still calling for heat and the furnace just shutting down on high limit?
Maybe you have an air lock and the water is not actually circulating through the pipes, there fore you are not heating properly...
Is the pump relay stuck closed and not releasing so that the pump keeps on running...
These are a few of the common problems and what I would check right when I came to look at your system to troubleshoot it...
Thank you for posting your question here on Fixya.com. Please contact me thru our website at www.arrowmotor.net and include the model information you provided here. We are an Armstrong repair center so I should have what you need in stock. I will send you a scan of the parts print for you to ID the parts you need. If you want a quote on those items we can provide that as well. If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! John
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
you should call and contact Bell & Gossett .(847)966-3700 Address: 8200 N. Austin Av. Morton Grove,IL 60053. Ask them that if the part no # 103400 Price $260 fits for your pump Good luck.
The most common problem with these circulators is that the stator gets stuck and does not turn.
Sometimes you can take out the four bolts on the corners and pull the motor off. Get the stator freed up again and it will work. Make sure to turn the water off before dissassembling the pump. Hopefully you have valves do you can isolate the pump.
Also check that the impeller has not broken off the end of the shaft, that also happens sometimes.
You can check the cap. with an OHM meter by switching the terminals with the test leads and the resistance should count down to zero with each switch of the leads on the terminals...if not it is bad, but replacement of the cap. may not fix the pump usually it is a secondary failure...
If you can't get the pump ot work after taking it apart and making sure it turns freely then I would replace the pump.
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
