20 Most Recent AO Smith SQ1202 Pool Pump Motor Questions & Answers
2answers
My a.o.smith sq1202 pump is slowly leaking water
Replace the leaking mechanical seal in the pump that is letting the water into the motor in the first place.
11/30/2013 11:49:08 PM • AO Smith SQ1202... • Answered on Nov 30, 2013
Pump buzzes won't start filter
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak. Start with the capacitor. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although It is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke. If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
4/22/2011 3:05:24 PM • AO Smith SQ1202... • Answered on Apr 22, 2011
How do you take off the motor from the pump
Turn the circuit breaker off to the pump. Undo the band that holds the motor and flex plate to the pump. Unscrew the 5 screws on the diffuser ( front of pump ) That will expose the impeller. Remove the rear cover of the motor, (2 -1/4" screw heads) Pull off the rear cover. The impeller might have a screw in the center of it. If it does, the screw is left handed thread. Turn the screw clockwise to remove. Use a 7/16" open end wrench to hold the shaft at the rear of the motor. Put the wrench behind the plate with the two springs on the shaft. You might have to turn the shaft a little to get the wrench on. Remove to screw and remove the impeller, (counter clockwise). Unscrew the 4 motor flange bolts and pull the flex plate from the motor.
4/13/2011 11:14:50 PM • AO Smith SQ1202... • Answered on Apr 13, 2011
I have a 2.5h 2
That model number is listed as a 230v motor (no neutral) The wires should be attached to terminals marked L1, L2 and A . L1 is high speed, L2 is common and A is low speed. Check the name plate for wiring information.
3/5/2011 3:13:29 AM • AO Smith SQ1202... • Answered on Mar 05, 2011
I have a AO smith SQ1202 motor driving a pump
http://www.waterwayplastics.com/catalogs/2011_poolspa_02_pumps.pdf
Here is the page with the pump curves, it took a while to find.
This lists from 3/4 HP to 3 HP in standard and energy efficient models.
If you need more information, post again.
Gary
1/5/2011 5:31:13 PM • AO Smith SQ1202... • Answered on Jan 05, 2011
2answers
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
11/11/2009 8:20:56 PM • AO Smith SQ1202... • Answered on Nov 11, 2009
Hayward pool motor shuts off in backwash mode.
Check the pump suction filter? To backwash it, is to
open the backwash tank cleanout valve, to clear the dirt out. If this does not work, check the pipelines going to the backwash tank for clogged lines.
11/1/2009 4:22:42 AM • AO Smith SQ1202... • Answered on Nov 01, 2009
How difficult is it to replace the bearings on an
Bearings MAY be bad from a bad seal. To do this right you MAY need an arbor press to insert new seal without damaging it.
8/5/2009 4:30:03 PM • AO Smith SQ1202... • Answered on Aug 05, 2009
Commroy
update your java
7/3/2014 12:28:23 AM • AO Smith... • Answered on Jul 03, 2014
I need to replace a 1hp cont pool pump motor and dont know which 2 get... please help
Probably, I assume everything is c-face and it has enough power.
6/18/2014 5:56:49 PM • AO Smith... • Answered on Jun 18, 2014
Water heater pilot turns on but burner won't light. 4 blink meaning high temp shutdown. What can I do?
We have a Model 2801052103 Franklin Electric submersible pump, 1/2HP 230 Volt. It starts and stops when using water frequently. System is 30+ years old, could the well be bad?
1/5/2014 9:57:06 PM • AO Smith... • Answered on Jan 05, 2014
My above ground pool pump (Hayward Pool Model
check flot
11/6/2013 9:33:43 PM • AO Smith... • Answered on Nov 06, 2013
2HP AO Smith on an
have a service person look at this motor
11/6/2013 9:33:08 PM • AO Smith... • Answered on Nov 06, 2013
Need tell end bearings for
call help desk
11/6/2013 9:25:42 PM • AO Smith... • Answered on Nov 06, 2013
I just replaced the seal, then I install back the
you may have change the motor rotation
11/6/2013 9:02:02 PM • AO Smith... • Answered on Nov 06, 2013
My water pump is locked and is making a hum noise.
IS IT AN ABOVEGROUND OR SUBMERSIBLE (INGROUND) PUMP. USUALLY THIS IS CAUSED BY A BAD CAPACITOR OR BURNT POINTS ON THE PRESSURE SWITCH. THE CAPACITOR IS EITHER IN A RELAY BOX AT THE WELL OR IN THE MOTOR CASING. HOPE THIS HELPS. JODY
1/16/2011 3:06:40 AM • AO Smith... • Answered on Jan 16, 2011
I have a spa 2 speed pump BN55 part 7 -186364 -02.
If the problem is the motor you could probably get the data needed off the motor's brand label and find an equivalent one on harborfreight.com or something.
12/17/2009 12:13:29 AM • AO Smith... • Answered on Dec 17, 2009
PREASURE NOT HIGH LIKE IT WAS 5 YEARS AGO
Plastic impellers and pump cases are great for circulation applications but tend to wear out in pressure and or dirty water applications. The space between the impeller and case gets larger as it wears until the pump just circulates water inside the case.
Pump selection is dependent on applications, with pressure, volume, suction, temperture and fluid to be pumped only a few of the considerations.
Check for restricted suction strainer and hose first, then look at discharge side for kinked hoses and other obstructions. Then open case and look for worn impeller and volutes, occasionally there will be something lodged in the impeller like string or plastic film. Replacing the impeller alone if badly worne may help but won't bring the pressure back to new pump specs, you will need to replace the volute or case too if they are combined.
I use cast iron pumps for pumping silt laden irrigation water and have to rebuild them every 5-6 years, My suction head is 3' and head pressure is 35 psi. frankly I expected better life from cast iron but have to take what I can get.
8/14/2009 5:07:59 PM • AO Smith... • Answered on Aug 14, 2009
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
AO Smith SQ1202 Pool Pump Motor Logo
10 questions posted
Top AO Smith Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
View Most Popular
AO Smith Plumbing
  • AO Smith Plumbing
Most Popular Question
2 5h 2
  • Plumbing
