20 Most Recent General Pump Pro Flat Surface Cleaner Questions & Answers
No water coming from pressure washer
Is there an adjustable dial or something that regulates the amount of spray that comes out. If so the problem is probably there.
4/18/2010 6:47:54 AM • General Pump Pro... • Answered on Apr 18, 2010
I let a pan run out of water and burned the pan up
Might try some oven cleaner, then finish up with stovetop cleaner for solid surfaces
3/8/2010 11:47:44 PM • General Pump Pro... • Answered on Mar 08, 2010
Surface cleaner is vibrating and I changed to tips
flip the unit over and rotate the bar,it could be bent. or the bearings are bad.
3/6/2010 4:27:25 AM • General Pump Pro... • Answered on Mar 06, 2010
Arm Rotary does not move
Sounds like you need a new swivel.
11/21/2009 12:24:34 AM • General Pump Pro... • Answered on Nov 21, 2009
General Pump "T 47 Series" TS1321 2100psi 4.75gpm. Schematic or diagram for GP T series 47 TS1321.
Question edited for clarity. Question moved from Cars and Trucks, because it isn't. help in the link, plus access to the maker. https://www.google.com/search?q=gp+t+series+47+ts1321+schematic+diagram ..
7/16/2023 11:04:50 PM • General Plumbing • Answered on Jul 16, 2023
Need presure wash head
for what model?
5/8/2012 1:20:02 AM • General Plumbing • Answered on May 08, 2012
Which tip for washing siding with bleach?
just remove the tip and spray it out but i think its the black tip there will be very low pressure while using this tip then swap tip to rinse
4/1/2012 2:16:14 AM • General Plumbing • Answered on Apr 01, 2012
I have a 5KC36MN2573 BX 3/4 hp motor with a
Take the four bolts out that hold the motor to the pump body...then carefully so that you do not ruin the gasket, get the motor the impeller and the pump face plate off of the pump body...it may take a bit or prying and tapping to get it apart...
Then comes the fun part...the impeller spins off of the motor shaft in the opposite direction of the rotation of the motor...so check the motor rotation and then you have to spin the impeller off of the motor shaft...a strap wrench works sometimes and sometimes you need to beat the impeller with a hammer and screw driver to get it off... holding the motor shaft at the same time can be a problem...sometimes you can get to the shaft and other motors have a screw driver slot or a nut at the back ot the motor to allow you to hold the shaft...this is best done with two people...
Once the impeller is off then the plate can slide off of the shaft... however you should replace the ceramic seal with a new one when installing a new motor...usually the old seal will leak if you do not... of course if you do not install the new seal very carefully it will leak also...
then place the plate on the new motor and spin the impeller on again....
For me... I usually always but a motor, impeller and seal when doing a job like this...
Good luck!!
heatman101
8/10/2011 6:44:01 PM • General Plumbing • Answered on Aug 10, 2011
Where can I find a user manual for a GE Jet Pump,
Did you ever get an answer on this? I have a similar model with a similar problem and can't get an answer anywhere?
11/28/2010 6:07:49 AM • General Plumbing • Answered on Nov 28, 2010
When i insert the plug the main motor will stop, i
their is 2 plugs one that goes into the other than that gets plugged in, unplug both , and only plug in the one cable with the prongs. the float on the pump is not working.
3/31/2010 10:57:54 AM • General Plumbing • Answered on Mar 31, 2010
Velocity variation (or flow pulsation) of a reciprocating pump
Please see the attached link, this may aid you.
http://www.1728.com/flowrate.htm
I hope this may have helped,
Tom
10/10/2009 5:56:46 AM • General Plumbing • Answered on Oct 10, 2009
How do i set the on and off times for an out...
You can download the Intermatic pdf file on installation and operation of your product.
http://www.intermatic.com/images/instruction_sheets/158ej11853.pdf
8/13/2009 4:25:50 PM • General Plumbing • Answered on Aug 13, 2009
Sump pump not pumping water properly
If your pump is turning then something is stopping the water from being removed. If you can see the pump check to see if the water is becoming turbulent when the pump kicks on? If the water doesn't appear to move or is moving only a little then either the pump impeller is damaged or the screen that keeps debris from entering the pump is clogged.
If it's never been cleaned it is most likely just a clogged filter screen. Clean it and it should work fine. If however the screen is clear then it is either a blocked line or a bad pump. And yes a pump can still run and not pump, if the impeller is bad.
5/22/2009 4:24:45 AM • General Plumbing • Answered on May 22, 2009
Can i make my motor run on 220
DONT KNOW WHAT KIND OF MOTOR THIS IS BUT : IF THE MOTOR SAYS 115/230 VOLT AC ON THE INFO TAG AND IT HAS A LOW/ HIGH WIRING DIAGRAGM THEN YOU SHOULD BE ABLE TO CONVERT IT. SOME MOTORS HAVE A SWITCH ON THE FRONT FACE WHERE YOU REMOVE A SCREW AND ROTATE A SHAFT. IF THIS DOESNT HELP GIVE MORE INFO. JODY
4/20/2009 3:12:37 AM • General Plumbing • Answered on Apr 20, 2009
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
General Pump Pro Flat Surface Cleaner Logo
Popular Tags
9 questions posted
Top General Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a General Plumbing Expert? Answer questions, earn points and help others
View Most Popular
General Plumbing
  • General Plumbing
Most Popular Question
no water coming from pressure washer
  • Plumbing
