20 Most Recent Saniflo 002/003/005 Saniplus Toilet with Macerator Series Pump in White Rou Questions & Answers
My daugther put baby wipes in my sani plus toilet
Check out DIY stores or on the sani wed site parts should not be a problem
12/9/2017 2:17:57 PM • Saniflo... • Answered on Dec 09, 2017
0answers
When toilet is flushed smell comes from handbasin
It sounds like the vent pipe may be clogged.
6/22/2011 2:27:47 PM • Saniflo... • Answered on Jun 22, 2011
3yr old saniflo + started making loud vibrating
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
6/20/2011 1:12:41 PM • Saniflo... • Answered on Jun 20, 2011
Water won't drain from sink or shower and the
there is a blockage in the saniflo pump or the saniflow outlet pipework
12/9/2010 7:26:29 PM • Saniflo... • Answered on Dec 09, 2010
2answers
It won't stop running
Sounds like the float switch is hung up or burnt out. hope this helps. duane.
5/10/2010 9:54:17 AM • Saniflo... • Answered on May 10, 2010
Saniplus pump runs and pumps a cup of water and
unlikely to be a vent problem - more likely a semi blocked 22mm outlet - hence the problem with the old unit & the new one. Tricky to solve as 22mm pipe runs are too small for conventional pipe cleaners. Some plumbers use compressed air to clear, others us pressured water (jetter) unfortunately it always ends up a bit messy.
5/10/2010 8:47:59 AM • Saniflo... • Answered on May 10, 2010
Saniflo Sanistar upflow wall hung toilet won't keep enough water level in bowl. Can't find where the float would be on it.
Some wall mount toilets can have the cistern fitted on the other side of the wall the bowl is mounted to so it appears 'Hidden'. Your float valve adjustment will be in there.
1/28/2024 11:44:44 PM • Saniflo Home • Answered on Jan 28, 2024
3answers
The bowl in my saniflo toilet has very low water level, and is getting lower. Would you please let me know how to fix this? Thank you, Erin
I know absolutely nothing about the Saniflo system other than the very basic working principle but logically there must be a vent or an airbreak between the macerator/pump unit and the toilet bowl or the pump would tend to create a depression in the container and draw water from the toilet bowl...
1/28/2024 11:43:47 PM • Saniflo Home • Answered on Jan 28, 2024
2answers
Chances of a new Saniflo up flush toilet with a bad capacitor?
That sounds like the issue. Saniflo provide them, so contact them for a free one. Article says it is inside the pressure vessel.
Saniflo Saniplus Capacitor, 45 Microfarad - SanifloStore.com
https://saniflostore.com > Saniflo-Saniplus-Capacitor-45... This replacement is slightly more involved as you have to open up the pressure chamber, once there though it is two small screws on junction box to release ... More here https://www.google.com/search?q=replace+saniflo+capacitor ..
11/7/2022 10:47:05 AM • Saniflo Home • Answered on Nov 07, 2022
How much water should be in the bowl of a saniflo best pro
How much water does the system use? All models in the Saniflo line are low consumption. The SaniPlus, SaniAccess (2 and 3), SaniBest Pro uses 1.28 gallons (4.8 liters) of water per flush.
Saniflo Installation Instructions
Videos as well https://www.google.com/search?q=How+much+water+should+be+in+the+bowl+of+a+saniflo+best+pro ..
10/9/2021 6:17:55 PM • Saniflo Home • Answered on Oct 09, 2021
Saniflo Plus toilet backs up when flushed then drains slowly. I just replaced the entire unit because the old one was doing the same thing. Any suggestions?
If drain is not clogged, check vent pipe to make sure it is clear. Sometimes birds or other critters build nests.
6/11/2019 11:57:12 PM • Saniflo Home • Answered on Jun 11, 2019
2answers
My bath will not empty. or the basin, but my macerator seems to be working. it is old, so maybe replacing is the best option....but i just wonder if my recent use of coconut oil in my bath (its lovely
Hi yes it's look like your pipes are block, pop up to any hardware shop and ask for something to unblock them. They will find
12/26/2018 12:33:35 PM • Saniflo Home • Answered on Dec 26, 2018
Saniflo 002/003/005 Saniplus Toilet with Macerator Series Pump in White Rou Logo
Popular Tags
12 questions posted
Top Saniflo Home Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
View Most Popular
Saniflo Home
  • Saniflo Home
Most Popular Question
when toilet flushed smell comes from
  • Home
