20 Most Recent
Kohler K-3492 Purist Hatbox Toilet Questions & Answers
KOHLER HATBOX TOILET WON'T REFILL AFTER FLUSHING.
There is a magnetic valve controlled by a micro-controller. You have to reset the micro-controller. Do the factory reset by following the factory reset instruction in the owner's manual. This will solve the problem.
W/c sounds like it is
eddyvillamil-
I am assuming you have a float ball and not a "fluidmaster" type valve. If so, the noise is caused by vibration in the stem and washer assembly.
To fix this yourself, shut
the water off under the tank and remove the three screws securing the
top of the ballcock assembly (located inside the tank). Pull the float
ball, stem and washer assembly up and out. Pry the rubber washer out and turn
it over. Seat the washer firmly and place your hand over the open ball **** while
you open up the stop to flush out any crud in the supply line. Reassemble and give it a
flush. The sound should be gone.
Hope this helps. If you get stuck or have a followup question, just reply to this message. If this has been helpful please take a moment to give me four thumbs up.
Regards,
DIYpro
For K-4392: What options do I have if the plumbing
If you are asking what options you have as a replacement non unless you can find a different brand that has the same rough-in measurements. Now it the carrier system behind the wall is adjustable then you may have more options.
