20 Most Recent Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with Questions & Answers
0answers
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
2/20/2013 2:57:11 PM • Kohler Persuade... • Answered on Feb 20, 2013
I have a Kohler Persuade toilet. It needs a top down screw in toilet seat in white wood, elongated, with chrome hardware. Know where I can find such an animal?
You should be able to get it direct from Kohler unless you can't find it at a specialty plumbing shop .
2/6/2013 7:32:21 AM • Kohler Persuade... • Answered on Feb 06, 2013
I can see water trickeling
The problem is your flapper. It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank. It will also solve most condensation issues as well.
8/29/2011 2:28:56 AM • Kohler Persuade... • Answered on Aug 29, 2011
Toilet running and won't stop.....it
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
5/17/2011 1:26:06 AM • Kohler Persuade... • Answered on May 17, 2011
Water level in bowl is too l;ow
There is a float in the back of the tank. It needs adjusted. I will explain more if you would like.
1/26/2011 6:31:10 PM • Kohler Persuade... • Answered on Jan 26, 2011
0answers
I'm about to install a kohler
Are you talking about the slot where the two screws hold the base down to the floor?
If so, that is called a closet flange. You will need to pick one up at Home Depot or Lowes. There are various kinds. If your floor is a concrete pad then you may have to get one that just slides down inside your waste pipe. It can be glued in. If you are upstairs and have a wooden sub floor you can get one with treated deck screws to screw into the floor.
If you have a digital camera, tale close up pictures of the waste site and take them to the store and show them to someone who works in the department. He will know what you need.
11/5/2009 12:33:29 AM • Kohler Persuade... • Answered on Nov 05, 2009
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)? All questions need to start 'make model (what it is)' first 3 words. And then a clear question. For the 13 people that have tagged this 10 year old question, it is better to post your own question. ..
2/7/2024 6:03:08 AM • Kohler Home • Answered on Feb 07, 2024
How do I do a factory reset on a Kohler Hatbox toilet please?
I have never heard of a toilet that needs an electronic reset, but it appears it is as simple as just disconnecting the power for 10 minutes. It does sound though are yours has a failing flush valve. I managed an airport lounge and we had dozens of electronic toilets and we had to keep a box of spares for them and just put new parts in them including complete control boards. We also kept a box of batteries. https://www.google.com/search?q=kohler+hatbox+toilet+factory+reset ..
2/7/2024 5:40:05 AM • Kohler Home • Answered on Feb 07, 2024
2answers
How to remove Kohler 1 piece toilet lid with single pull handle in the middle of the lid
Lift and pull the lid forward lift up and disconnect the lift lever from the chain.
2/24/2023 1:35:18 AM • Kohler Home • Answered on Feb 24, 2023
2answers
How do you tighten the toilet seat on a Kohler Escale toilet?
https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1095641_2.pdf
10/15/2021 8:04:37 PM • Kohler Home • Answered on Oct 15, 2021
Kohler Whirlpool jets are weak.
Kohler has good support. You can view the diagrams for that unit with the link I am posting. There are no filters listed in the diagram that might need to be cleaned. There is a chance that the unit has developed a clog from hair etc in the pump impellor. The flange may have come loose and is allowing air in the suction side of the pump too. Kohler has online chat and support numbers you can call too. K-1357-RA ' Devonshire 5-Foot Whirlpool with Apron and Right Drain ' KOHLER
8/13/2021 2:05:35 PM • Kohler Home • Answered on Aug 13, 2021
2answers
How to adjust the water presure on a Kohler K-T14422-3 shower head
just turn the water valve down some
5/21/2021 8:50:19 PM • Kohler Home • Answered on May 21, 2021
2answers
How do I fix KOHLER Touchless toilet it keeps flushing, it is less than 6 months old
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
1/9/2020 11:21:38 AM • Kohler Home • Answered on Jan 09, 2020
Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with Logo
11 questions posted
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
kohler persuade toilet won 39 t fill up
  • Home
