20 Most Recent Kohler Model 10430: Fort® Single-control Remote Valve Kitchen Sink Fauc... Questions & Answers
2answers
My kohler k-r10430 drips when
replace the cartridge, if your not which one, just take the old one with you to the plumbing supply house
10/19/2018 12:07:44 AM • Kohler Model... • Answered on Oct 19, 2018
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking. If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
10/18/2017 8:32:55 PM • Kohler Model... • Answered on Oct 18, 2017
Have Kohler diverter, GP 75878
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
4/21/2014 7:06:10 AM • Kohler Model... • Answered on Apr 21, 2014
How do you install part gp75878
You need patience/care to open up the faucet and replace the parts. See if you can understand the diagram on page 15 of the installation guide. The link to the guide is: http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1084448_2.pdf
2/23/2014 2:20:09 AM • Kohler Model... • Answered on Feb 23, 2014
I cannot figure out how
Under the handle, there is a curved trim ring at the top that needs to be unscrewed from the base. This can be on tight due to hard water buildup. I cut two strips of rubber to wrap, one to wrap around the trim ring and the other to wrap base while using channel locks for the trim ring and a pipe wrench to keep the base from turning.After that is off, you will see a large hex head retainer nut that holds the valve assembly in place. A spanner wrench will get that off fairly easy. Reassembly is the reverse. Kohler specs the hex nut to be torqued at 9 ft-lbs or 1//4 turn past hand tight.
11/12/2012 2:03:16 AM • Kohler Model... • Answered on Nov 12, 2012
How do I open the
The handle has a allen set screw loosen that until the handle comes off then the bonnet nut will unscrew revealing the bonnet cap and washer the cartridge should be under that most kohler's require a special tool to remove cartridge(turn water to faucet off prior to working on faucet,also note how everything is removed it needs to be replaced in same order especially the cartridge,also you should use plumbers grease to coat all seal when replacing everything).
6/13/2011 11:57:28 PM • Kohler Model... • Answered on Jun 13, 2011
I've taken the spout off and can see the diverter
I have a K-R10430. I was having issues with the hand spray - poor water pressure. Kholer sent out a new diverter. After shutting off watner, when you remove the small screw in the back of the Spout, pull the spout off. Put a paper towel into the body to soak up excess water inside body. Then you need a small screw driver or small flat item to fit inside one side of the retaining ring near the opening, there is a space where you can fit something behind and carefully move the retaining ring out. Pull out with needle nose pliers then pull the diverter out with needle nose pliers. Insert new diverter with teeth facing up and push down. Insert retaining ring and make sure it slips into same **** in wall of body.
1/9/2011 10:18:34 PM • Kohler Model... • Answered on Jan 09, 2011
The water spout has developed a free play in the
if you undo the grub screw the outlet will pull out there is a o-ring in there this may need to be replaced
7/14/2010 2:03:42 PM • Kohler Model... • Answered on Jul 14, 2010
No water passes from faucet to hand sprayer
try soaking it in some CLR calcium lime and rust remover .
3/18/2009 2:26:00 AM • Kohler Model... • Answered on Mar 18, 2009
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps: First, turn off the water supply to the faucet. Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key. Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off. Once the plastic insert is removed, you should be able to access the cartridge. If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
1/14/2024 12:29:26 PM • Kohler Plumbing • Answered on Jan 14, 2024
Manual and guide to replacing parts in Kohler Model 10430
Parts diagrams. Instruction for changing are normally on the Kohler website. Or Google make model replace (the part). https://www.google.com/search?q=kohler+model+10430+replacement+parts ..
12/4/2022 12:47:33 AM • Kohler Plumbing • Answered on Dec 04, 2022
2answers
Have Taboret K 8201-4 bathroom faucet with T handles.
Question edited to fix the typos. Always worrying when they discontinue lines, and it makes you wonder why? https://www.us.kohler.com/us/taboret-centerset-bathroom-sink-faucet-with-lever-handles/productDetail/product:420060/420060.htm I normally find that they use steel screws and they stick. Make some sort of a dam around the screw with stout polythene like Ziploc bag and electrical tape to seal the base. Then squirt penetrating oil or WD40 in there to cover the screw head. Top it up a couple of times a day and do that for two days. That should loosen it up and get the oil down the threads. Often it is just easier to buy a new set.
9/23/2022 12:45:42 PM • Kohler Plumbing • Answered on Sep 23, 2022
Tines stripped on recessed aerator how to remove
call kohler
12/13/2021 11:09:03 PM • Kohler Plumbing • Answered on Dec 13, 2021
Is there a video of replacing o ring on a 77809/AA kohler leaking under handleplease
you tube is the video website
5/28/2021 5:05:40 PM • Kohler Plumbing • Answered on May 28, 2021
Kohler one handle shower faucet fixture will not turn off
Look up the Kohler 800 number. Their parts have a lifetime warranty and they will gladly send a replacement part.
11/6/2019 10:53:41 PM • Kohler Plumbing • Answered on Nov 06, 2019
Is there suppose to be a o ring at the bottom when replacing a kohler taboret cartridge
I assume you mean the separate H/C valve body as opposed to single handle(bath/shower). https://www.us.kohler.com/us/Taboret-t-handles/productDetail/product:417141/417141.htm?skuId=341208 There is one O ring just below threads of body. k1-5ywlvxu2h1hgmzvnljvnapjw-2-0.png
4/22/2019 10:42:13 AM • Kohler Plumbing • Answered on Apr 22, 2019
2answers
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
12/26/2018 1:35:54 PM • Kohler Plumbing • Answered on Dec 26, 2018
Kohler Model 10430: Fort® Single-control Remote Valve Kitchen Sink Fauc... Logo
Popular Tags
28 questions posted
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Kohler Plumbing
  • Kohler Plumbing
Most Popular Question
ve taken spout off see diverter
  • Plumbing
