20 Most Recent
Rohl R77V3SPN Country Pull-Out Bar Faucet with Short Handspray - Polished N... Questions & Answers
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
How do I replace the hose on a rohl 3810 faucet
contact ROHL customer Service, request a new hose (part number R45158), detach the end on the underside with a wrench and pull it out. Insert new hose through the topside guide neck and reconnect on the bottom connection.
Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
I have a Rohl R77V3STN Pull Out Faucet, and the
Call customer service right away. 1 800 777 9762
Mine is now stuck, and she said if I had called when it was still moving, they could send a free part. The only other option would be that they send a refurb faucet for a $50 charge. I said no thanks, I'm not paying another cent for this faucet--there's a lifetime warranty! The warranty states replacement of product or parts free of charge.
I'll try the part. as the faucet will move if I force it. (I used a little wd40).
Apparently mine was made in New Zealand, where the water doesn't have as much chlorine.
If the part doesn't work, I'm calling them back and raising the roof!!
I'm going tobe replacing the cartridge in my Rohl
It is highly suggested to use the grease. The purpose of the grease is for (break-in Period). Without the grease, gaskets and seals rub dry and hard against the metal surfaces and could distort or wear uneven and fail prematurely. The grease helps ease the initial wear and give a better life. Also, it isrecommended toopen a faucet and clean and grease seals and gaskets before they are bad;sort of a preventive maintainance every 2 to 3 years. Good luck, Macgivor
I have a R77V3 in
- Everything you will need to know can be found. Pics and Step By Step Directions.
- If you have any questions, just ask me
- http://plumbing.hardwarestore.com/learning/how-to-repair-faucets.aspx
Just copy and paste the above link in our internet address bar under a new tab.
I have a Rohl
Appears you have a blockage in the hose itself.
Remove and use a piece of wire to clear the blockage.
