20 Most Recent
Kohler K-14402-4A-SN Purist Single Control Lavatory Faucet with Straight Le... Questions & Answers
Spray head is clogged
Remove the aerator by unscrewing it. Clean out the crud that is probably clogging the screen.
1/18/2014 1:05:49 AM •
Kohler...
Answered
on Jan 18, 2014
How do i unclog the spray head
Here is the breakdown for that faucet:
Kohler K-14402
Go to page 6 to see how to remove the aerator. You may need a special tool. This can be ordered from Kohler at 1-800-456-4537.
Hope this helps!
1/6/2014 10:40:36 AM •
Kohler...
Answered
on Jan 06, 2014
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
