20 Most Recent Kohler K-10270-4-BV Forte Two Handle Centerset Lavatory Faucet with Sculpte... Questions & Answers
Hi Lee, CCW Lefty loosey, Righty tighty, LOL Have fun at it.
Kohler... | Answered on Oct 02, 2013
Cut off water supply to faucet remove allen screw that hold handle on remove handle unscrew bonnet nut then take out cartridge and put in new one.Make sure you note how old came out so you can put new one in correctly
Kohler... | Answered on Jun 12, 2011
There is a small set screw on the handle it may be covered with a small cover that needs to be removed to reveal the set screw.
Kohler... | Answered on Mar 04, 2011
I assume you mean the separate H/C valve body as opposed to single handle(bath/shower).
https://www.us.kohler.com/us/Taboret-t-handles/productDetail/product:417141/417141.htm?skuId=341208
There is one O ring just below threads of body.
Kohler Plumbing | Answered on Apr 22, 2019
Only if you don't mind having to replace the valve after you finish forcing it with pliers.
Kohler Plumbing | Answered on Jan 08, 2019
Should be a pretty easy fix, you need to remove the faceplate for the faucet then there should be a gap between the wall in the faucet valve and you should be able to see two screws that are holding it on to the wood stud in the wall, you can remove the screws and put a couple washes behind the valve that way it will bring it out further and you should be able to get your handle on it without a problem.
Kohler Plumbing | Answered on Dec 26, 2018
Pop the cap off the faucet handle and tighten the screw under it.
Kohler Plumbing | Answered on Nov 15, 2018
If this is a tub/ shower valve, you installed the cart. upside down. Reversing it should solve the problem. You might have put it in according to instructions but the hot and cold might have been reversed when the valve was plumbed in.
Kohler Plumbing | Answered on Oct 08, 2018
replaces the tap washer or insert
The bottom half of the handle spins CCW to losses the handle from the body. You can then tighten the screw inside the handle.
There is normally a tag on one of the supply lines.
It takes new valve cartridges and sometime complete valve bodies. Call Kohler, it should be covered by their lifetime warranty. They are very good about service.
Kohler Plumbing | Answered on Oct 07, 2018
Kohler K-10270-4-BV Forte Two Handle Centerset Lavatory Faucet with Sculpte... Logo
Popular Tags
7 questions posted
Top Kohler Plumbing Experts
Mike
Donni Steen
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Kohler Plumbing
  • Kohler Plumbing
Most Popular Question
nut hot faucet
  • Plumbing
