20 Most Recent
Kohler K-10270-4A-G Forte Centerset Lavatory Faucet with Traditional Lever... Questions & Answers
Lav center set faucet handle removal model K10271
The handle may be secured with a set screw in the body of the handle that must be loosened before the handle will lift off the valve - the set screw will require an appropriately-sized hex (or "allen") wrench. If you cannot find a set screw on the handle, then the handle is friction fit - in which case no tools are required, just a bit of force to lift the handle off.
Hope this helps. Post a reply if you need further assistance.
DIYpro
5/17/2011 10:44:56 PM •
Kohler...
Answered
on May 17, 2011
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
