20 Most Recent Price Pfister Savannah Two-Handle Kitchen Faucet with Matching Spray .... Questions & Answers
I have a Savannah Price
Google your faucet and add how to fix leak there is a video on there site that shows you how to do it .
12/9/2017 2:15:11 PM • Price Pfister... • Answered on Dec 09, 2017
The spout of my faucet keeps blowing off when I
First this is a very unusual assurance and the spout retainer ring needs to be replaced.
To help relieve the pressure on this part for the time being by removing the aerator it is probably plugged up anyway.
3/7/2011 10:21:51 AM • Price Pfister... • Answered on Mar 07, 2011
Re: Price-Pfister Savannh kitchen faucet: Leaks
Sorry we are not able to help you with your problem.
1/4/2011 2:34:16 AM • Price Pfister... • Answered on Jan 04, 2011
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
9/6/2010 1:50:32 PM • Price Pfister... • Answered on Sep 06, 2010
Dripping faucet
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
7/26/2010 3:31:45 AM • Price Pfister... • Answered on Jul 26, 2010
Leaking at the base of the riser spiggot and tends
Some have washers at base of spout.
5/5/2010 10:21:55 PM • Price Pfister... • Answered on May 05, 2010
I have Price pfister Savannah
Yes to fix it you will need to replace the cartirdges. If you can figure out exactly which one is dripping you could just do that one.
I often find these guys to be very competitive and give me great pricing, even better then the local plumbing supply that I deal with. If I have the time for shipping I often buy here.
http://pricepfisterparts.faucetdirect.com/
Hope you have a great day!!
Heatman101
1/29/2010 1:39:24 AM • Price Pfister... • Answered on Jan 29, 2010
I have very low almost no water pressure
check under the sink you will find to water pipes one hot one cold there is a nob/vavles on both they control the water pressure make sure they are open all the way. if that doesnt work goo the water heater and by it you wil find one pipe off the heater and one by it with the same valves just make sure they are open all the way
11/9/2009 5:39:51 PM • Price Pfister... • Answered on Nov 09, 2009
Problem with Price Pfister Savannah Two-Handle
Sounds like there is loose solder in the supply pipes. You would have to disconnect the flexs and blow it out.
9/14/2009 1:00:30 AM • Price Pfister... • Answered on Sep 14, 2009
2answers
Installed a new price pfister two knob kitchen
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
7/28/2009 1:21:07 PM • Price Pfister... • Answered on Jul 28, 2009
''poor pressure hot water only on new 531 series''
If you remove the supply line from the faucet and open the valve into a bucket, do you have adequate pressure? If you do, you will need to remove the hot water stem to see if something washed up into the faucet when you first turned the water on.
4/11/2009 3:51:59 AM • Price Pfister... • Answered on Apr 11, 2009
4answers
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
1/9/2022 10:19:46 PM • Price Pfister... • Answered on Jan 09, 2022
I have a price pfister single handle kitchen faucet How do I adjust the water temperature? Water is not hot enough
It has to be adjusted at the water heater.
12/30/2018 10:09:43 PM • Price Pfister... • Answered on Dec 30, 2018
Need diagram for price pfister bath clean out
10/8/2018 2:05:41 AM • Price Pfister... • Answered on Oct 08, 2018
Price Pfister Marielle, 26 series, leaks around the top of the spout body when water is turned on. How do I take it apart and fix the leak?
1 under the sink turn off both water supplies 2 disconnect the supply lines at the on/off valve EZer than at faucet 3 under sink unscrew the retaining nut(s) 4 on top wiggle or pry the faucet and lift up and remove. 5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring . 6 Reinstall check for leaks 7 caulk around faucet. Hope this helps Mike
5/31/2018 8:08:37 PM • Price Pfister... • Answered on May 31, 2018
Have Price pfister kitchen faucet...the hot water has slowed to a trickle. Not the source -plenty coming in and after replacing cartridge with new from Price Pfizer-no change. Any ideas?
Back to the basics...did you turn the hot water shutoff back on? Is it a multi-turn shutoff or a 1/4-turn one? If it was old, and multi-turn, the washer could be shot, and it is all clogged. Try disconnecting the hose and see if you can get any flow into a bucket from the connection. There could be some crud caught inside of the cartridge, so you might need to remove it and flush it out. Price Pfister single handle sink faucet no hot water
2/12/2018 4:05:50 AM • Price Pfister... • Answered on Feb 12, 2018
MY PRICE PFISTER 533-50 HAS
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy. aaaaaelftksuqmccaa==
12/30/2017 11:21:09 PM • Price Pfister... • Answered on Dec 30, 2017
Buying a replacement part for price pfister a cartridge #21137. Kitchen faucet 15 years old.where can I buy onr Is there a new part #?
take the old one to the store with you they can match it up.. (home depot... lowes)...
10/2/2017 6:27:33 PM • Price Pfister... • Answered on Oct 02, 2017
Price Pfister Savannah Two-Handle Kitchen Faucet with Matching Spray .... Logo
22 questions posted
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Price Pfister Plumbing
Most Popular Question
faucet dripping
  • Plumbing
